求大神给个adxl345单双击程序,我对着传感器敲半天没反应
2327|0
 楼主| sky657 发表于 2013-6-23 21:50 | 显示全部楼层 |阅读模式
//初始化ADXL345,根据需要请参考pdf进行修改************************
void Init_ADXL345()
   Single_Write_ADXL345(0x31,0x2B);   //中断低电平有效;测量范围,正负16g,13位模式
   Single_Write_ADXL345(0x2C,0x08);   //速率设定为12.5 参考pdf13页
   Single_Write_ADXL345(0x2D,0x08);   //选择电源模式   参考pdf24页
Single_Write_ADXL345(0x2E,0x00);//全部中断disable
Single_Write_ADXL345(0x2E,0x40);//单击中断able
   Single_Write_ADXL345(0x2F,0x9F);   //仅将单击双击配置为中断1
:)   Single_Write_ADXL345(0x1D,0xf);   //单击触发加速度设为1g
:)  Single_Write_ADXL345(0x21,0xff);   //单击触发最长时间,最高
