"net contains unplated pads",是怎么回事?(99se)
13134|1
 楼主| cnchip 发表于 2009-3-6 17:27 | 显示全部楼层 |阅读模式
Protel&nbsp;Design&nbsp;System&nbsp;Design&nbsp;Rule&nbsp;Check<br />PCB&nbsp;File&nbsp;:&nbsp;HDN-956-01&nbsp;V2.3更新中....PCB<br />Date&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;:&nbsp;6-Mar-2009&nbsp;<br />Time&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;:&nbsp;17:03:20<br /><br />WARNING:&nbsp;Unplated&nbsp;multi-layer&nbsp;pad(s)&nbsp;detected<br />&nbsp;&nbsp;&nbsp;Pad&nbsp;4-1(15.15999mm,5.00002mm)&nbsp;&nbsp;MultiLayer&nbsp;on&nbsp;Net&nbsp;GND<br />&nbsp;&nbsp;&nbsp;Pad&nbsp;3-1(155.15999mm,5.00002mm)&nbsp;&nbsp;MultiLayer&nbsp;on&nbsp;Net&nbsp;GND<br />&nbsp;&nbsp;&nbsp;Pad&nbsp;2-1(155.15999mm,115.00003mm)&nbsp;&nbsp;MultiLayer&nbsp;on&nbsp;Net&nbsp;GND<br />&nbsp;&nbsp;&nbsp;Pad&nbsp;1-1(15.15999mm,115.00003mm)&nbsp;&nbsp;MultiLayer&nbsp;on&nbsp;Net&nbsp;GND<br />Total:&nbsp;4<br /><br />Processing&nbsp;Rule&nbsp;:&nbsp;Short-Circuit&nbsp;Constraint&nbsp;(Allowed=Not&nbsp;Allowed)&nbsp;(On&nbsp;the&nbsp;board&nbsp;),(On&nbsp;the&nbsp;board&nbsp;)<br />Rule&nbsp;Violations&nbsp;:0<br /><br />Processing&nbsp;Rule&nbsp;:&nbsp;Broken-Net&nbsp;Constraint&nbsp;(&nbsp;(On&nbsp;the&nbsp;board&nbsp;)&nbsp;)<br />&nbsp;&nbsp;&nbsp;Violation&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;Net&nbsp;GND&nbsp;&nbsp;<br />&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;<font color=#FF0000>Warning&nbsp;-&nbsp;net&nbsp;contains&nbsp;unplated&nbsp;pads</font><br />Rule&nbsp;Violations&nbsp;:1<br /><br />Processing&nbsp;Rule&nbsp;:&nbsp;Clearance&nbsp;Constraint&nbsp;(Gap=0.2mm)&nbsp;(On&nbsp;the&nbsp;board&nbsp;),(On&nbsp;the&nbsp;board&nbsp;)<br />Rule&nbsp;Violations&nbsp;:0<br /><br /><br />Violations&nbsp;Detected&nbsp;:&nbsp;1<br />Time&nbsp;Elapsed&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;:&nbsp;00:00:11<br /><br />还是没弄懂,似乎跟最上面提示的那四个Pad有关吗?郁闷。。。
天命风流 发表于 2014-11-18 11:31 | 显示全部楼层
同求!
