[AVR单片机] ATmega128,用595连接数码管,如何编程序,很茫然,求帮助。
3778|20
Black残 发表于 2013-7-25 15:28 | 显示全部楼层
贴两个AVR单片机128  74HC595的数码管程序 给你参考  一个是4位数码管循环显示0-F  另外一个是秒表
#include<iom128v.h>
#include<macros.h>
#define uchar unsigned char
#define uint unsigned int
#pragma data:code
const  table[]={0xc0,0xf9,0xa4,0xb0,0x99,0x92,0x82,0xf8,0x80,0x90,0x88,0x83,0xc6,0xa1,0x86,0x8e};
void delay(void)
         uint i;
           for(i=0;i<65000;i++);
void main()
int k=4,j=0;
DDRA=0xFF;
DDRC=0xFF;
PORTC=0xFF;
while(1)
   for(k=4;k<8;k++)
         if(j>=16)
         j=0;
     PORTA=table[j];
     PORTC=~BIT(k);
     delay();
     delay();
     delay();
         delay();
         j++;
#include <iom128v.h>
#include <macros.h>
#pragma interrupt_handler timer1:15
uint num = 0;
#pragma data:code
const uchar duan[]={0xc0,0xf9,0xa4,0xb0,0x99,0x92,0x82,0xf8,
const uchar wei[]={0x7f,0xbf,0xdf,0xef};
void DelayMs(uint i)
    while(i--)
            uint j;
        for(j=1;j<=613;j++);
void show(uchar j,uchar k)
         PORTA = duan[j];
         PORTC = wei[k];
         if(k==2)
          PORTA = duan[j]&(~BIT(7));
         if(k==0&&(num%2==0))
void main()
         uint i,j;
         DDRA = 0xff;   //数码管段选
         DDRC = 0xff;   //位选
         TCCR1A = 0x00;
         TCCR1B = 0x04;//256分频
         TCNT1H=0X48;
         TCNT1L=0XE4;//计数寄存器
         TIMSK|=BIT(2);//中断屏蔽寄存器
         SEI();//开启总中断
         while(1)
             show(num%60%10,0);
                 DelayMs(2);
                 show(num%60/10,1);
                 DelayMs(2);
                 show(num/60%10,2);
                 DelayMs(2);
                 show(num/600,3);
                 DelayMs(2);
void timer1(void)
         TCNT1H=0X48;
         TCNT1L=0XE4;
         num++;
         if(num==3600)
           num=0;
