为什么信号线和丝印层出现短路的错误提示啊
3246|2
 楼主| nanger1984 发表于 2009-5-17 20:40 | 显示全部楼层 |阅读模式
哪位高手帮我解决一下啊,我用的是protell&nbsp;99&nbsp;se,错误如下:<br />&nbsp;&nbsp;Processing&nbsp;Rule&nbsp;:&nbsp;Short-Circuit&nbsp;Constraint&nbsp;(Allowed=Not&nbsp;Allowed)&nbsp;(On&nbsp;the&nbsp;board&nbsp;),(On&nbsp;the&nbsp;board&nbsp;)<br />&nbsp;&nbsp;&nbsp;Violation&nbsp;between&nbsp;Text&nbsp;&quot;104&quot;&nbsp;(-60.88388mm,29.85812mm)&nbsp;&nbsp;TopLayer&nbsp;and<br />&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;Track&nbsp;(-71.5518mm,29.8958mm)(-56.134mm,29.8958mm)&nbsp;&nbsp;TopLayer<br />&nbsp;&nbsp;&nbsp;Violation&nbsp;between&nbsp;Text&nbsp;&quot;104&quot;&nbsp;(-60.88388mm,29.85812mm)&nbsp;&nbsp;TopLayer&nbsp;and<br />&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;Track&nbsp;(-67.02702mm,31.0896mm)(-48.9204mm,31.0896mm)&nbsp;&nbsp;TopLayer<br />Rule&nbsp;Violations&nbsp;:2<br />&nbsp;&nbsp;谢谢啊
一级菜鸟 发表于 2009-5-17 21:18 | 显示全部楼层
哪有人把标号印在TOPLAYER信号层的?
顶层丝印层是TopOverlay
 楼主| nanger1984 发表于 2009-5-18 18:57 | 显示全部楼层
感谢啊
呵呵,原来怎么简单啊。我把丝印隐藏了,所以怎么都看不到短路的地方,哈哈哈,谢谢啊
