[逆变器]
STM32高级定时器设置函数导致仿真失败
1823|0
xinxin3219|  楼主 | 2013-7-5 14:17 | 只看该作者 回帖奖励 |倒序浏览 |阅读模式
RT~真是,昨天搞了一天的STLINK,终于能在线仿真了,但是我程序中的高级定时器设置函数会引起STLINK仿真失败,真是奇葩问题。论坛里的大侠有遇到过这个情况吗,TIM1设置函数如下,纠结,将这个函数在
主程序中的调用注释掉就能正常仿真了,不注释掉的话,单步调试执行完该函数后就跳出“内部命令错误”等调试异常信息。不注释掉的话,在全速仿真下,我看变量一次更新后没法再次更新就被迫退出调试模式。
void Tim1_Configuration(void)
  TIM_TimeBaseInitTypeDef TIM_TimeBaseStructure;
  TIM_OCInitTypeDef TIM_OCInitStructure;
  TIM_BDTRInitTypeDef TIM_BDTRInitStructure;
  /* Time Base configuration */
  TIM_TimeBaseStructure.TIM_Prescaler = 0;
  TIM_TimeBaseStructure.TIM_CounterMode = TIM_CounterMode_Up;
  TIM_TimeBaseStructure.TIM_Period = 9000-1;  //8k          //PWMƵÂÊΪ8K
  TIM_TimeBaseStructure.TIM_ClockDivision = 0;
  TIM_TimeBaseStructure.TIM_RepetitionCounter = 0;
  TIM_TimeBaseInit(TIM1, &TIM_TimeBaseStructure);
  //ÇåÖжÏ
  TIM_ClearFlag(TIM1, TIM_FLAG_Update);
  //TIM1ÖжÏÔ´ÉèÖ㬿ªÆôÏàӦͨµÀµÄÏòÉÏÒç³öÖжÏ
  TIM_ITConfig(TIM1, TIM_IT_Update, ENABLE);
  /* Channel 3 Configuration in PWM mode */
  TIM_OCInitStructure.TIM_OCMode = TIM_OCMode_PWM2;                           //Êä³öÅäÖÃΪPWM2ģʽ
  TIM_OCInitStructure.TIM_OutputState = TIM_OutputState_Enable;   //ʹÄÜÊä³ö±È½Ï״̬
  TIM_OCInitStructure.TIM_OutputNState = TIM_OutputNState_Enable; //ʹÄÜ»¥²¹Êä³ö
  TIM_OCInitStructure.TIM_Pulse = 2250;                                                          //Âö³å¿í¶È
  TIM_OCInitStructure.TIM_OCPolarity = TIM_OCPolarity_Low;           //
  TIM_OCInitStructure.TIM_OCNPolarity = TIM_OCNPolarity_Low;
  TIM_OCInitStructure.TIM_OCIdleState = TIM_OCIdleState_Set;
  TIM_OCInitStructure.TIM_OCNIdleState = TIM_OCIdleState_Set;
  TIM_OC3Init(TIM1, &TIM_OCInitStructure);
  /* Channel 2 Configuration in PWM mode */
  TIM_OC2Init(TIM1, &TIM_OCInitStructure);
  /* Channel 1 Configuration in PWM mode */
  TIM_OC1Init(TIM1, &TIM_OCInitStructure);
  /* Automatic Output enable, Break, dead time and lock configuration*/   //ËÀÇøÉèÖÃ
  TIM_BDTRInitStructure.TIM_OSSRState = TIM_OSSRState_Enable;
  TIM_BDTRInitStructure.TIM_OSSIState = TIM_OSSIState_Enable;
  TIM_BDTRInitStructure.TIM_LOCKLevel = TIM_LOCKLevel_1;
  TIM_BDTRInitStructure.TIM_DeadTime = 0xAC;                                //ÕâÀïµ÷ÕûËÀÇø´óС0-0xff    ËÀÇø3US
  //TIM_BDTRInitStructure.TIM_DeadTime = 0xCD;                                   //5us
  TIM_BDTRInitStructure.TIM_Break = TIM_Break_Disable;                   //ɲ³µ£¬Ê§ÄÜ
  TIM_BDTRInitStructure.TIM_BreakPolarity = TIM_BreakPolarity_High;
  TIM_BDTRInitStructure.TIM_AutomaticOutput = TIM_AutomaticOutput_Disable;
  TIM_BDTRConfig(TIM1, &TIM_BDTRInitStructure);
  TIM_OC1PreloadConfig(TIM1,TIM_OCPreload_Enable);           //¿ªÆôÔ¤×°ÔØ
  TIM_OC2PreloadConfig(TIM1,TIM_OCPreload_Enable);
  TIM_OC3PreloadConfig(TIM1,TIM_OCPreload_Enable);
  /* TIM1 counter enable */
  TIM_Cmd(TIM1, ENABLE);
  /* Main Output Disnable */
  TIM_CtrlPWMOutputs(TIM1, ENABLE);
