<br />在安装时"select xilinx modules" 全选择(用并口下载线,用的ise 6.2)<br />xilinx下载时能找到并口设备,但出现下列问题:<br />ERROR:iMPACT:585 - A problem may exist in the hardware configuration.<br /> Check that the cable, scan chain, and power connections are intact,<br /> that the specified scan chain configuration matches the actual hardware, and<br /> that the power supply is adequate and delivering the correct voltage.<br />是什么原因?用usb接口的也是这样.是否还需要并口的其他驱动程序.<br /> <br /> |
