c8051f120的128K 的flash高64k如何应用
5308|0
 楼主| tao180539 发表于 2013-7-12 16:36 | 显示全部楼层 |阅读模式
c8051f120的128K 的flash的高64K如何应用
http://liangrj2005.blog.163.com/blog/static/11238804520093113194574/
这个上面说的 我弄的不对啊
Build target 'Target 1'
linking...
*** ERROR L107: ADDRESS SPACE OVERFLOW
    SPACE:   BANK2
    SEGMENT: ?PR?ATTENTION_CHANGE_STANDARD?ATTENTION
    LENGTH:  0029H
    SPACE:   BANK2
    SEGMENT: ?PR?ATTENTION_RASTER_PROBLEM?ATTENTION
    LENGTH:  0029H
    SPACE:   BANK2
    SEGMENT: ?PR?PRINTE_INIT?PRINTE
    LENGTH:  0021H
    SPACE:   BANK2
    SEGMENT: ?PR?_PRINT_SEND_INT?PRINTE
    LENGTH:  001FH
*** WARNING L19: COMMON CODE SEGMENTS LOCATED TO BANKED AREA
*** ERROR L118: REFERENCE MADE TO ERRONEOUS EXTERNAL
    SYMBOL:  ATTENTION_CHANGE_STANDARD
    MODULE:  .\编译\Electrode_C.obj (ELECTRODE_C)
    ADDRESS: 64C0H
    SYMBOL:  ATTENTION_RASTER_PROBLEM
    MODULE:  .\编译\Selftest_C.obj (SELFTEST_C)
    ADDRESS: B843H
*** ERROR L105: PUBLIC REFERS TO IGNORED SEGMENT
    SYMBOL:  _PRINT_SEND_INT
    SYMBOL:  PRINTE_INIT
*** ERROR L120: CONTENT BELONGS TO ERRONEOUS SEGMENT
    MODULE:  .\编译\Printe.obj (PRINTE)
    MODULE:  .\编译\Attention.obj (ATTENTION)
Program Size: data=38.2 xdata=830 code=65657
Target not created
