贴一个自己常用的I2c和按键模块!
2319|1
 楼主| lacfg 发表于 2013-7-15 12:00 | 显示全部楼层 |阅读模式
I2c:
#define _HC_EEPROM
#define MAX_ONE_PAGE 0x7f
#define MAX_ADDRESS 0xffff
void I2cPageWrite(unsigned int Address,unsigned int Length,unsigned char *Data_Handle)
        if((Length-1)>(MAX_ADDRESS-Address))
                I2c_State=NO_ENOUGH_ROM;
        else
                while(Length>0)
                        I2c_State=I2C_WRITTING;
                        I2cStart();
                        I2cSend(I2C_WRITE_COMMAND);
                        #ifdef _HC_EEPROM
                                I2cSend((unsigned char)(Address/256));
                        #endif
                        I2cSend((unsigned char)(Address%256));
                        do
                                I2cSend(*Data_Handle);
                                Length--;
                                Data_Handle++;
                                Address++;
                        }while(((Address&MAX_ONE_PAGE)!=0)&&(Length>0));
                        I2cStop();
                        I2cDelay();
                I2c_State=I2C_WRITE_OVER;
void I2cPageRead(unsigned int Address,unsigned int Length,unsigned char *Data_Handle)
                I2c_State=OVER_MAX_ROM;
        else
                while(Length>0)
                        I2c_State=I2C_READING;
                        I2cStart();
                        #ifdef _HC_EEPROM
                        #endif
                        I2cStart();
                        I2cSend(I2C_READ_COMMAND);
                        do
                                *Data_Handle=I2cRead();
                                Length--;
                                Data_Handle++;
                                Address++;
                                if(Length>0)
                                        I2cAck();
                                else
                                        I2cNoAck();
                        }while(Length>0);
                        I2cStop();
                I2c_State=I2C_READ_OVER;
按键处理:
typedef struct Key_Ele
        unsigned State                                :1;
        unsigned UnPushed                        :7;
        unsigned int Pushed                           ;
        unsigned int Speed                          ;
}Key_Element;
void KeyScanAndSerV()
        static unsigned char Key_Ing=0,Key_Over=0,Key_Scan=0;
        static Key_Element Key_Scanning[5]=0;
        Key_Scanning[0].State=READ_KEY0;
        Key_Scanning[1].State=READ_KEY1;
        Key_Scanning[2].State=READ_KEY2;
        Key_Scanning[3].State=READ_KEY3;
        Key_Scanning[4].State=READ_KEY4;
        if(Key_Scanning[Key_Scan].State==0)
                if(Key_Scanning[Key_Scan].Pushed<65535)
                        Key_Scanning[Key_Scan].Pushed++;
                if(Key_Scanning[Key_Scan].Pushed>=NUM_PUSHED_JUDGE)
                        Key_Scanning[Key_Scan].UnPushed=0;
                        Key_Ing=Key_Scan+1;
        else
                if(Key_Scanning[Key_Scan].UnPushed<120)
                        Key_Scanning[Key_Scan].UnPushed++;
                if(Key_Scanning[Key_Scan].UnPushed>NUM_RELEASE_JUDGE)
                                Key_Over=Key_Scan+1;
                        Key_Scanning[Key_Scan].Pushed=0;
        Key_Scan++;
        if(Key_Scan==5)
                Key_Scan=0;
        switch(Key_Over)
                case 1:
                        if(Key_Scanning[0].Speed==0)
                                //按键1无持续按松手时的操作
                                CharValAdd(Num_Pointer);
                                //按键1松手时的操作
                        Key_Over=0;
                        Key_Scanning[0].Speed=0;
                        break;
                case 2:
                        if(Key_Scanning[1].Speed==0)
                                //按键2无持续按松手时的操作
                                CharValReduce(Num_Pointer);
                                //按键2松手时的操作
                        Key_Over=0;
                        Key_Scanning[1].Speed=0;
                        break;
                case 3:
                        if(Key_Scanning[2].Speed==0)
                                //按键3无持续按松手时的操作
                                //按键3松手时的操作
                                if(Num_Pointer==&Num_Page_A)
                                        Num_Pointer=&Num_Page_B;
                                        Smg_1.InvalidZero_NoDis=0;
                                else
                                        if(Num_Pointer==&Num_Page_B)
                                                Num_Pointer=&Num_Page_A;
                                                Smg_1.InvalidZero_NoDis=1;
                        Key_Over=0;
                        Key_Scanning[2].Speed=0;
                        break;
                case 4:
                        if(Key_Scanning[3].Speed==0)
                                //按键4无持续按松手时的操作
                                //按键4松手时的操作
                                Smg_1.Flash=!Smg_1.Flash;
                                IR_Learn_Mode=!IR_Learn_Mode;
                                WRITE_LED_LEARN_OVER=1;
                                for(i=0;i<8;i++)
                                        IR_Code_OneFrame[i]=0;
                        Key_Over=0;
                        Key_Scanning[3].Speed=0;
                        break;
                case 5:
                        if(Key_Scanning[4].Speed==0)
                                //按键5无持续按松手时的操作
                                //按键5松手时的操作
                                IR_Save_Code=1;
                        Key_Over=0;
                        Key_Scanning[4].Speed=0;
                        break;
                default:
                        break;
        switch(Key_Ing)
                case 1:
                        Key_Ing=0;
                        if(Key_Scanning[0].Pushed>NUM_CONTINUE_PUSHED_JUDGE)
                                Key_Scanning[0].Pushed=NUM_PUSHED_JUDGE+Key_Scanning[0].Speed;
                                        //按键1持续按时的操作
                                if(Key_Scanning[0].Speed<NUM_SPEED_MAX)
                                                Key_Scanning[0].Speed+=NUM_SPEED_ADD;
                        break;
                case 2:
                        Key_Ing=0;
                        if(Key_Scanning[1].Pushed>NUM_CONTINUE_PUSHED_JUDGE)
                                Key_Scanning[1].Pushed=NUM_PUSHED_JUDGE+Key_Scanning[1].Speed;
                                        //按键2持续按时的操作
                                if(Key_Scanning[1].Speed<NUM_SPEED_MAX)
                                                Key_Scanning[1].Speed+=NUM_SPEED_ADD;
                        break;
                case 3:
                        Key_Ing=0;
                        if(Key_Scanning[2].Pushed>NUM_CONTINUE_PUSHED_JUDGE)
                                Key_Scanning[2].Pushed=NUM_PUSHED_JUDGE+Key_Scanning[2].Speed;
                                        //按键3持续按时的操作
                                if(Key_Scanning[2].Speed<NUM_SPEED_MAX)
                                                Key_Scanning[2].Speed+=NUM_SPEED_ADD;
                        break;
                case 4:
                        Key_Ing=0;
                        if(Key_Scanning[3].Pushed>NUM_CONTINUE_PUSHED_JUDGE)
                                Key_Scanning[3].Pushed=NUM_PUSHED_JUDGE+Key_Scanning[3].Speed;
                                        //按键4持续按时的操作
                                if(Key_Scanning[3].Speed<NUM_SPEED_MAX)
                                                Key_Scanning[3].Speed+=NUM_SPEED_ADD;
                        break;
                case 5:
                        Key_Ing=0;
                        if(Key_Scanning[4].Pushed>NUM_CONTINUE_PUSHED_JUDGE)
                                Key_Scanning[4].Pushed=NUM_PUSHED_JUDGE+Key_Scanning[4].Speed;
                                        //按键5持续按时的操作
                                if(Key_Scanning[4].Speed<NUM_SPEED_MAX)
                                                Key_Scanning[4].Speed+=NUM_SPEED_ADD;
                        break;
                default:
                        break;
wsnsyy 发表于 2013-7-15 14:52 | 显示全部楼层
段落稍微注释一下就好了
