这个错误是怎么回事
2086|2
 楼主| acer4736 发表于 2013-7-18 23:23 | 显示全部楼层 |阅读模式
Warning L52
EVAL Version Used Before, Rebuild all *.OBJ Files
Summary   *** Warning L52
    Module: filename (module-name)
Description   The specified module has been build with a code size restricted version (Eval Version). You should rebuild all *.OBJ files of your project to ensure that no file implies code size limits for your project.
Cause   Typically this problem occurs when an Eval Version has been used before or a project was created before a license has been activated on this computer.
Resolution   Rebuild the complete project.
PSoC Creator的问题
kk5290122 发表于 2013-7-19 12:27 | 显示全部楼层
应该是你Creator里面有些组件不对应吧,需要更新
