[51单片机] pcf8591 AD程序困惑
1945|0
 楼主| manu2013 发表于 2013-7-19 21:53 | 显示全部楼层 |阅读模式
#include<reg52.h>
#define uchar unsigned char
#define uint unsigned int
bit  write=0;
//sbit sda=P2^0;
//sbit scl=P2^1;
sbit sda=P1^0;
sbit scl=P1^1;
sbit CS_DA =P2^4 ;  //HJ-3G DAC HL-1不需要,可以关掉
uchar a;
void delay()
void init()
   CS_DA =0 ;
        sda=1;
        delay();
        scl=1;
        delay();
void start()  //开始信号
        sda=1;
        delay();
        scl=1;
        delay();
        sda=0;
        delay();
void stop()   //停止
        sda=0;
        delay();
        scl=1;
        delay();
        sda=1;
        delay();
void respons()  //应答
        uchar i;
        scl=1;
        delay();
        while((sda==1)&&(i<250))i++;
        scl=0;
        delay();
void write_byte(uchar date)
        uchar i,temp;
        temp=date;
        for(i=0;i<8;i++)
                temp=temp<<1;
                scl=0;
            delay();
                sda=CY;
                delay();
                scl=1;
                delay();
        scl=0;
        delay();
        sda=1;
        delay();
uchar read_byte()
        uchar i,k;
        scl=0;
        delay();
        sda=1;
        delay();
        for(i=0;i<8;i++)
                scl=1;
                delay();
                k=(k<<1)|sda;
                scl=0;
                delay();
        return k;
void write_add(uchar address,uchar date)
        start();
        write_byte(0x90);
        respons();
        write_byte(address);
        respons();
        write_byte(date);
        respons();
        stop();
uchar read_add(uchar address)
        uchar date;
        start();
        write_byte(0x90);
        respons();
        respons();
        start();
        write_byte(0x91);
        respons();
        date=read_byte();
        stop();
        return date;
uchar ad(uchar add)                //ad转换输出函数
        uchar a;
        init();
        a=read_add(add);
        return a;
请问“sbit CS_DA =P2^4 ;  //HJ-3G DAC HL-1不需要,可以关掉”“CS_DA =0 ;”作用是什么?为什么我把它删掉AD就不能正常工作呢??我用的是慧净HL-1 V8.0
