星期的显示无法实现。望高人指导!!!
#include<reg52.h>
#include<string.h>
#include "yejing.h"
#define uchar unsigned char
#define uint unsigned int
sbit s1=P1^4;
sbit s2=P1^5;
sbit s3=P1^6;
sbit s4=P1^7;
uchar code table0[]=" 2013-12-30";
uchar code table1[]=" 23:59:53";
uchar table2[3];
uchar t0,s1num,xingqi;
char shi,fen,miao,nian,yue,ri;
void init()
uchar num;
s1num=0;
miao=0x35;
fen=0x3b;
shi=0x17;
nian=13;
yue=12;
ri=30;
initlcd();
writecom(0x80+2);
for(num=0;num<11;num++)
writedate(table0[num]);
delay(5);
writecom(0x80+0x40);
for(num=0;num<12;num++)
writedate(table1[num]);
delay(5);
TMOD=0x01;
TH0=(65536-50000)/256;
TL0=(65536-50000)%256;
EA=1;
ET0=1;
TR0=1;
void writesfm(uchar add,uchar date)
uchar sh,ge;
writecom(add+0x80+0x40);
sh=date/10;
ge=date%10;
writedate(0x30+sh);
writedate(0x30+ge);
void writenyr(uchar add,uchar date)
uchar sh,ge;
writecom(add+0x80);
sh=date/10;
ge=date%10;
writedate(0x30+sh);
writedate(0x30+ge);
void writexq(uchar xq)
uchar num;
//xq++;
if(xq==8)
xq=1;
writecom(0x80+12);
switch(xq)
case 1:writedate('M');delay(5);break;
case 2:writedate('T');delay(5);break;
case 3:writedate('W');delay(5);break;
case 4:writedate('H');delay(5);break;
case 5:writedate('F');delay(5);break;
case 6:writedate('S');delay(5);break;
case 7:writedate('U');delay(5);break;
writecom(12+0x80);
for(num=0;num<3;num++)
writedate(table2[num]);
delay(5);
void keyscan() //最重要的一个函数;;?
if(s1==0) //判断功能键;?
delay(5);
if(s1==0)
{ s1num++;
while(!s1);
if(s1num==1)
TR0=0;
writecom(0x80+0x40+11);
writecom(0x0f);
} //设置好光标后直接关闭判断语句;;?
if(s1num==2)
writecom(0x80+0x40+8);
if(s1num==3)
writecom(0x80+0x40+5);
if(s1num==4)
writecom(0x80+12);
if(s1num==5)
writecom(0x80+9);
if(s1num==6)
writecom(0x80+6);
if(s1num==7)
s1num=0;
writecom(0x0c);
TR0=1;
if(s1num!=0)
if(s2==0)
delay(5);
if(s2==0)
while(!s2);
if(s1num==1)
miao++;
if(miao==60)
miao=0;
writesfm(10,miao);
if(s1num==2)
fen++;
if(fen==60)
fen=0;
writesfm(7,fen);
if(s1num==3)
shi++;
if(shi==24)
shi=0;
writesfm(4,shi);
if(s1num==4)
ri++;
if(ri==32)
ri=1;
writenyr(11,ri);
writecom(0x80+12);
if(s1num==5)
yue++;
if(yue==13)
yue=1;
writenyr(8,yue);
writecom(0x80+9);
if(s1num==6)
nian++;
writenyr(5,nian);
writecom(0x80+6);
if(s3==0)
delay(5);
if(s3==0)
while(!s3);
if(s1num==1)
miao--;
if(miao==-1)
miao=59;
writesfm(10,miao);
if(s1num==2)
fen--;
if(fen==-1)
fen=59;
writesfm(7,fen);
if(s1num==3)
shi--;
if(shi==-1)
shi=23;
writesfm(4,shi);
if(s1num==4)
ri--;
if(ri==0)
ri=31;
writenyr(11,ri);
writecom(0x80+12);
if(s1num==5)
yue--;
if(yue==0)
yue=12;
writenyr(8,yue);
writecom(0x80+9);
if(s1num==6)
nian--;
writenyr(5,nian);
writecom(0x80+6);
void timer0() interrupt 1
t0++;
if(t0==20)
t0=0;
miao++;
if(miao==60)
miao=0;
fen++;
if(fen==60)
fen=0;
shi++;
if(shi==24)
shi=0;
ri++;
writexq(++xingqi);
//writecom(0x80+12);
//xingqi++;
if(ri==32)
ri=1;
yue++;
if(yue==13)
yue=1;
nian++;
writenyr(5,nian);
writenyr(8,yue);
writenyr(11,ri);
// delay(5);
writesfm(4,shi);
writesfm(7,fen);
writesfm(10,miao);
void main()
init();
while(1)
keyscan();
//以下为"yejing.h"
sbit rs=P2^0;
sbit rw=P2^1;
sbit en=P2^2;
sbit bu=P0^7;
void delay(uint xms)
uint i,j;
for(i=xms;i>0;i--)
for(j=110;j>0;j--);
/*bit bt()
bit res;
rs=0;
rw=1;
en=1;
res=bu;
delay(5);
//en=1;
//delay(5);
en=0;
return res;
void writecom(uchar com)
//while(bt()==1);
rs=0;
rw=0;
en=0;
P0=com;
delay(5);
en=1;
delay(5);
en=0;
void writedate(uchar date)
//while(bt()==1);
rs=1;
rw=0;
en=0;
P0=date;
delay(5);
en=1;
delay(5);
en=0;
void initlcd()
rw=0;
rs=0;
en=0;
delay(5);
writecom(0x38);
delay(2);
writecom(0x38);
delay(2);
writecom(0x0c);
delay(2);
writecom(0x06);
delay(2);
writecom(0x01);
delay(2);
