问题:Nios中出现的错误信息
1779|0
 楼主| 飞天巨人 发表于 2008-10-16 21:15 | 显示全部楼层 |阅读模式
NIOS, ce, AD, USB, se
Using&nbsp;cable&nbsp;&quot;USB-Blaster&nbsp;[USB-0]&quot;,&nbsp;device&nbsp;1,&nbsp;instance&nbsp;0x00<br />Pausing&nbsp;target&nbsp;processor:&nbsp;OK<br />Initializing&nbsp;CPU&nbsp;cache&nbsp;(if&nbsp;present)<br />OK<br /><br />Downloading&nbsp;00000000&nbsp;(&nbsp;0%)<br />Downloaded&nbsp;1KB&nbsp;in&nbsp;0.0s&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;<br /><br />Verifying&nbsp;00000000&nbsp;(&nbsp;0%)<br />Verify&nbsp;failed&nbsp;between&nbsp;address&nbsp;0x0&nbsp;and&nbsp;0xE7<br />Leaving&nbsp;target&nbsp;processor&nbsp;paused<br />在nios中出现是什么意思?怎么解决?谢谢各位了
