FEATURES:
• Digital-output X-, Y-, and Z-Axis angular rate sensors (gyroscopes) with a user-programmable full-scale range of ±250, ±500, ±1000, and ±2000°/sec
• External sync signal connected to the FSYNC pin supports image, video and GPS synchronization
• Integrated 16-bit ADCs enable simultaneous sampling of gyros
• Enhanced bias and sensitivity temperature stability reduces the need for user calibration
• Improved low-frequency noise performance
• Digitally-programmable low-pass filter
• Gyroscope operating current: 3.6mA
• Standby current: 5μA
• Factory calibrated sensitivity scale factor
• User self-test
产品规格:
1T1R WLAN Single Chip-RTL8188ETV
• CMOS MAC, Baseband PHY and RF in a single chip for IEEE802.11b/g/n compatible WLAN
• 150Mbps receive PHY rate and 150Mbps transmit PHY rate using 40MHz bandwidth
• Complies with USB 1.0/1.1/2.0 for WLAN
• 46-pin QFN
2T2R WLAN Single Chip-RTL8192CU
• 2x2 MIMO technology for extended reception robustness and exceptional
• 300Mbps receive PHY rate and 300Mbps transmit PHY rate using 40MHz bandwidth
• Compatible with 802.11n specification
• Complies with USB 2.0
