活跃一下气氛,发一个源代码公开的CPU软核MIPS789
3743|1
 楼主| arwei 发表于 2007-12-6 11:58 | 显示全部楼层 |阅读模式
This&nbsp;is&nbsp;a&nbsp;soft&nbsp;processor&nbsp;core&nbsp;written&nbsp;in&nbsp;verilog-2001&nbsp;with&nbsp;five&nbsp;pipeline&nbsp;stages&nbsp;which&nbsp;supports&nbsp;almost&nbsp;MIPSI&nbsp;instructions.&nbsp;MIPS789&nbsp;supports&nbsp;gcc-elf-mips&nbsp;tools&nbsp;provided&nbsp;by&nbsp;Steve&nbsp;Rhords,&nbsp;author&nbsp;of&nbsp;plasma.In&nbsp;fact,&nbsp;this&nbsp;core&nbsp;is&nbsp;designed&nbsp;based&nbsp;on&nbsp;this&nbsp;complier.&nbsp;I’ve&nbsp;tested&nbsp;it&nbsp;by&nbsp;using&nbsp;a&nbsp;lot&nbsp;of&nbsp;C&nbsp;programs&nbsp;in&nbsp;a&nbsp;CYCLONE&nbsp;device&nbsp;EP1C6Q240&nbsp;at&nbsp;50MHZ&nbsp;frequence&nbsp;and&nbsp;it&nbsp;worked&nbsp;so&nbsp;well.&nbsp;By&nbsp;calculation,&nbsp;its&nbsp;CPI&nbsp;(cycle&nbsp;per&nbsp;instruction)&nbsp;is&nbsp;about&nbsp;1.1&nbsp;when&nbsp;run&nbsp;common&nbsp;programs.<br /><br />下载地址是:http://www.opencores.org/projects.cgi/web/mips789/overview<br /><br />里面包含所有的源泉代码以及编译器以及一些小工具软件。<br /> 相关链接:<a href='http://www.opencores.org/projects.cgi/web/mips789/overview'>http://www.opencores.org/projects.cgi/web/mips789/overview</a>
liangzhitu 发表于 2007-12-6 12:14 | 显示全部楼层
回复
能否给出MIPS指令系统看看吗???
