[LED驱动] MPS 推出Offline LED 控制IC( with Active PFC)
1950|5
 楼主| LED狂人 发表于 2013-8-26 16:56 | 显示全部楼层 |阅读模式
Monolithic Power System (NASDAQ: MPWR) 推出 MP4026, 此产品为primary-side-control, offline LED controllerMP4026内含功率因子校正操作在BCM模式(boundary-conduction mode), MP4026并提供多重保护包括over-voltage protection, short-circuit protection, primary-side over-current protection, brown out protection, cycle-by-cycle current limiting, VCC under-voltage lockout, and auto-restart over-temperature protection。
【方案特色】
Real-Current Control without Secondary-Feedback Circuit
Good Line/Load Regulation
High Power Factor (≥0.9) over Universal Input Voltage
Boundary Conduction Mode for Improved Efficiency
Brown-Out Protection
Over-Voltage Protection
Short-Circuit Protection
Over-Temperature Protection
Primary-Side Over-Current Protection
Cycle-by-Cycle Current Limit
Input UVLO
Available in FCTSOT-6
【系统方块图】
【规格说明】
The Key Specifications:
Market Applications:
Industrial and Commercial Lighting
Residential Lighting
TYPICAL APPLICATION:
【方案参考档】
zh113214 发表于 2013-8-26 21:50 | 显示全部楼层
MPS's service provided in clude module Turnkey Royalty and Components
 楼主| LED狂人 发表于 2013-8-27 15:02 | 显示全部楼层
不懂这个
008ming 发表于 2013-8-29 15:06 | 显示全部楼层
libin1009 发表于 2013-10-5 09:48 | 显示全部楼层
MPS的方案是不错的,就是有点贵!
kubimofang 发表于 2013-10-9 11:23 | 显示全部楼层
这个方案还不错,不知道输出功率多大
