[AVR单片机] M128似乎进不了主程序,看门狗正常。
1549|3
 楼主| cpu51 发表于 2013-8-28 11:11 | 显示全部楼层 |阅读模式
//ICC-AVR application builder : 2013/8/28 9:07:52
// Target : M128
// Crystal: 11.059Mhz
#include <iom128v.h>
#include <macros.h>
#include <math.h>
#include <stdio.h>
void delay(unsigned int ms);
void delay_ms(unsigned int ms);
#define run_led_h    PORTF|=(1<<PF7)   //置高电平
#define run_led_l    PORTF&=~(1<<PF7) //拉低电平
#define comm_led_h    PORTF|=(1<<PF6)   //置高电平
#define comm_led_l    PORTF&=~(1<<PF6) //拉低电平
  unsigned int i;
   for(i=0;i<ms;i++)
                   _NOP();_NOP();_NOP();_NOP();_NOP();_NOP();_NOP();
  unsigned int i;
   for(i=0;i<ms;i++)
    delay(780);
        WDR();
void port_init(void)
PORTA = 0xFF;
DDRA  = 0xFF;
PORTB = 0x00;
DDRB  = 0x03;
PORTC = 0xFF; //m103 output only
DDRC  = 0xFF;
PORTD = 0xFF;
DDRD  = 0xFF;
PORTE = 0xFE;
DDRE  = 0xFE;
PORTF = 0x5F;
DDRF  = 0xFF;
PORTG = 0x00;
DDRG  = 0x00;
//UART0 initialize
// desired baud rate: 9600
// actual: baud rate:9600 (0.0%)
// char size: 8 bit
// parity: (Reserved)
void uart0_init(void)
UCSR0B = 0x00; //disable while setting baud rate
UCSR0A = 0x00;
UCSR0C = 0x16;
UBRR0L = 0x47; //set baud rate lo
UBRR0H = 0x00; //set baud rate hi
UCSR0B = 0x18;
//Watchdog initialize
// prescale: 2048K
void watchdog_init(void)
WDR (); //this prevents a timeout on enabling
WDTCR |= (1<<WDCE) | (1<<WDE);// 30-Oct-2006 Umesh
WDTCR = 0x0F; //WATCHDOG ENABLED - dont forget to issue WDRs
WDTCR = 0x00;
//call this routine to initialize all peripherals
void init_devices(void)
//stop errant interrupts until set up
CLI(); //disable all interrupts
XDIV  = 0x00; //xtal divider
XMCRA = 0x00; //external memory
port_init();
PORTF = 0xEF;
DDRF  = 0xFF;
uart0_init();
MCUCR = 0x00;
MCUCSR=0x00;
EICRA = 0x00; //extended ext ints
EICRB = 0x00; //extended ext ints
EIMSK = 0x00;
TIMSK = 0x00; //timer interrupt sources
ETIMSK = 0x00; //extended timer interrupt sources
//SEI(); //re-enable interrupts
//all peripherals are now initialized
void main(void)
//CLI();
init_devices();
while(1)  //在端口初始化中,F口是5F,有2个LED灯亮,主程序中将LED
          //全熄灭。但实际只有2个灯一直亮,似乎进不到主程序中。
PORTF = 0xFF;
DDRF  = 0xFF;
delay(2000);
PORTF = 0x0F;
DDRF  = 0xFF;
delay(2000);
huangxz 发表于 2013-8-28 11:43 | 显示全部楼层
配置位有问题没,
又是个icc的,呵呵。
qin552011373 发表于 2013-8-28 19:37 | 显示全部楼层
你是不是直接生成的程序?把你自己写的程序拿下去看看能不能正常
 楼主| cpu51 发表于 2013-8-30 20:19 | 显示全部楼层
已经解决了,是ICC里面的芯片配置忘了配置。
个人签名:承接工业远程控制系统及设计研发,DCS控制系统,无线采集控制系统,单片机设计,工业设备维修,仪器仪表、控制系统维护、检修。
99
