[MCU] 义隆EM78P259 TCC仿真怎么这么不准?
2625|2
 楼主| wzy8430121 发表于 2013-9-5 12:06 | 显示全部楼层 |阅读模式
我用CLK=4测试 用示波器测量  发现脉冲的周期是128us  但是理论上来说应该是0.125us  请问是什么情况?
#include "EM78P259N.h"
#define DISI()  _asm{disi}
#define ENI()   _asm{eni}
#define RET()   _asm{RET}
#define MOV()   _asm{mov A, @0x00} //0分频
#define CONTW() _asm{contw}
#define CLRA()  _asm{clra}
#define SLEP()  _asm{slep}
#define LED  R61
extern int IntVecIdx; //occupied 0x10:rpage 0
void main(void)
        _asm
                        nop
                        nop
                        nop
                        nop
                        nop
                        nop
        MOV();
        CONTW();
        WDTCR=0X00;
        P5CR=0xFF;
        P6CR=0X00;
        LED=0;
        TCC=255;
        ISR=0;
        IMR=0x01;
        ENI();
        while(1);
void _intcall ALLInt(void) @ int
  switch(IntVecIdx)
    case 0x4:
    break;
    case 0x7:
    break;
    case 0xA:
        if(TCIF == 1)
                TCIF=0;
                TCC=255;
                LED=!LED;
    break;
    case 0xD:
    break;
    case 0x10:
    break;
    case 0x13:
    break;
    case 0x16:
    break;
    case 0x19:
    break;
    case 0x1C:
    break;
    case 0x1F:
    break;
void _intcall extinterrupt_l(void) @ 0x03:low_int 0
_asm{MOV A,0x2
      BC 0x3,5
void _intcall port5pinchange_l(void) @ 0x06:low_int 1
_asm{MOV A,0x2
      BC 0x3,5
void _intcall tcc_l(void) @ 0x09:low_int 2
_asm{MOV A,0x2
      BC 0x3,5
void _intcall ADconvert_l(void) @ 0x0C:low_int 3
_asm{MOV A,0x2
      BC 0x3,5
void _intcall comparator_l(void) @ 0x0F:low_int 4
_asm{MOV A,0x2
      BC 0x3,5
void _intcall highpulse_l(void) @ 0x12:low_int 5
_asm{MOV A,0x2
      BC 0x3,5
void _intcall lowpulse_l(void) @ 0x15:low_int 6
_asm{MOV A,0x2
      BC 0x3,5
void _intcall tcca_l(void) @ 0x18:low_int 7
_asm{MOV A,0x2
      BC 0x3,5
void _intcall tccb_l(void) @ 0x1B:low_int 8
_asm{MOV A,0x2
      BC 0x3,5
void _intcall tccc_l(void) @ 0x1E:low_int 9
_asm{MOV A,0x2
      BC 0x3,5
 楼主| wzy8430121 发表于 2013-9-6 11:08 | 显示全部楼层
cuilaiabc 发表于 2014-1-8 14:18 | 显示全部楼层
我78p468,定时也不准,我也是用示波器测的。
