一个简单的光强度检测程序
3231|20
 楼主| huangchui 发表于 2013-9-8 16:37 | 显示全部楼层 |阅读模式
BH1750FVI是光强度传感器,支持IIC接口。小弟最近欲做一个简单的光强度检测程序,将光强度用数码管显示出来,不过调试了好久一直无法工作。请各位大虾帮忙看下IIC的模拟哪里有错,不胜感激!
#include<msp430x14x.h>
#define uchar unsigned char
#define uint unsigned int
#define SDA_1  P3OUT|=BIT1 // P3.1为SDA
#define SDA_0  P3OUT&=~BIT1
#define SCL_1 P3OUT |= BIT0 //P3.0为SCL
#define SCL_0 P3OUT &= ~BIT0
#define DIR_IN P3DIR &= ~BIT1
#define DIR_OUT P3DIR |= BIT1
#define SDA_IN ((P3IN >> 1) & 0x01)
#define dis_data  P5OUT  //数码管输出
#define TIME 5
#define SlaveAddress   0xA6
uchar seg_bcd[] = {0xC0,0xF9,0xA4,0xB0,0x99,0x92,0x82,0xF8,0x80,0x90,0x88,0x83,0xc6,0xa1,0x86,0x8e}; //数码管
void delay_nms(unsigned int k)//延时k毫秒
   unsigned int i,j;
   for(i=0;i<k;i++)
       for(j=0;j<121;j++)
void Delay(unsigned int n)    //延时
    unsigned int i;
    for(i = 0;i < n;i++)
void BH1750_Start()         //起始信号
     DIR_OUT;
     SDA_1;
    delay_nms(5);
     SCL_1;
     Delay(TIME);
     SDA_0;
     Delay(TIME);
     SCL_0;
void BH1750_Stop()        //结束信号
     DIR_OUT;
     SDA_0;
     Delay(TIME);
     SCL_1;
     Delay(TIME);
     SDA_1;                    }
void BH1750_SendACK()       //发送Ack
     SCL_0;
     DIR_OUT;
     SDA_0;
     Delay(TIME);
     SCL_1;
     Delay(TIME);
     SCL_0;
void BH1750_RecvACK()         //接受ACK
{   SCL_1;
    Delay(TIME);
     DIR_IN;
     while(SDA_IN);
     DIR_OUT;
     SCL_0;
     Delay(TIME);
void BH1750_SendByte(uchar dat)     //发送一个字节
{   DIR_OUT;
     unsigned int i;
     for(i = 0;i < 8;i++)
     SCL_0;
     Delay(TIME);
     if((dat >> 7) & 0x01) SDA_1;
     else SDA_0;
    Delay(TIME);
     SCL_1;
     Delay(TIME);
     dat <<= 1; //数据左移一位,进入下一轮送数
     Delay(TIME);
uchar BH1750_RecvByte()         //接受一个字节
     uchar i;
     uchar dat = 0;
     uchar datbit=0;
     SCL_0;
     Delay(TIME);
     SDA_1;
     DIR_IN;
     for (i=0; i<8; i++)
         SCL_1;
        Delay(TIME);
        datbit = SDA_IN;
         Delay(TIME);
         dat = ((dat << 1) | datbit);
         SCL_0;
        Delay(TIME);
     return dat;
void Single_Write_BH1750(uchar REG_Address)  //写入
     BH1750_Start();
     BH1750_SendByte(SlaveAddress);
     BH1750_SendByte(REG_Address);
   // BH1750_SendByte(REG_data);
     BH1750_Stop();
void main()
{ uchar tmp;
   float temp;
   int t;
   WDTCTL = WDTPW + WDTHOLD;
   P5DIR |= 0Xff;
   P4DIR |= 0x01;
   P5OUT |= 0x00;
   delay_nms(200);
   Single_Write_BH1750(0x01);
   Single_Write_BH1750(0x10);
  while(1)
    { Single_Write_BH1750(0x01);
      delay_nms(180);
      tmp=BH1750_RecvByte();
      temp=(float)tmp;
      t=temp/100;
      dis_data=seg_bcd[t];
wuhany 发表于 2013-9-8 16:39 | 显示全部楼层
BH1750FVI这个东西真的不了解。看看有没有了解的人。
个人一点看法:不要简单的贴代码。很少有人会有耐心看既不知道原理图又不知道具体应用的代码,对大家来说是个挑战。
jiaxw 发表于 2013-9-8 16:39 | 显示全部楼层
硬件连接有没有问题?检查下BH1750FVI外围电路正常否。
liliang9554 发表于 2013-9-8 16:41 | 显示全部楼层
对,比如做了哪些实验?有什么现象?
IIC通信的地址波特率设置正确否?
wuhany 发表于 2013-9-8 16:42 | 显示全部楼层
用示波器抓图看看波形。
 楼主| huangchui 发表于 2013-9-8 16:42 | 显示全部楼层
好的,我挨个儿排查下
 楼主| huangchui 发表于 2013-9-8 16:43 | 显示全部楼层
谢谢大家了,结贴啦,周末愉快
haitun1895 发表于 2013-9-8 17:22 | 显示全部楼层
我是看不懂的哦;
1988020566 发表于 2013-9-10 00:13 | 显示全部楼层
你也得检测一下电路的。
1988020566 发表于 2013-9-10 00:14 | 显示全部楼层
有可能是你io电平有问题的,加个上啦电阻之类的。
mmbs 发表于 2013-9-11 10:58 | 显示全部楼层
使用示波器测试一下波形。
dirtwillfly 发表于 2013-9-11 11:29 | 显示全部楼层
看iic最好还是 用示波器或者逻辑分析仪
opal11 发表于 2013-9-12 23:49 | 显示全部楼层
看不懂。
cat3902982 发表于 2013-9-12 23:59 | 显示全部楼层
我觉得可以上逻辑分析仪看看那!
yangguangaisha 发表于 2013-9-21 16:26 | 显示全部楼层
正好与我的工作有点关系 下载看看
gexingyouxian 发表于 2013-9-21 17:08 | 显示全部楼层
留着备用 呵呵
firstblood 发表于 2013-9-23 23:39 | 显示全部楼层
光强度检测话应该主要是用到AD采集的吧,直接采集传感器书吃的电压或者电流信号的吧,,,
zhao3462910 发表于 2013-9-24 09:23 | 显示全部楼层
光强度检测话应该主要是用到AD采集的吧,直接采集传感器书吃的电压或者电流信号的吧,,, ...
IIC接口,他的是数字型的吧??
