[C语言] 这个程序编译能通过,就是不能正常运行,求大神拍砖
1613|0
 楼主| zhaotao108 发表于 2013-9-13 10:24 | 显示全部楼层 |阅读模式
/*数码管动态显示*/
#include<reg52.h>
#define DataPort P0
sbit LATCH1=P2^2;/*段锁存*/
sbit LATCH2=P2^3;/*位锁存*/
unsigned char code dofly_DuanMa[10]={0x3f,0x06,0x5b,0x4f,0x66,0x6d,0x7d,0x07,0x7f,0x6f};
unsigned char code dofly_WeiMa[]={0xfe,0xfd,0xfb,0xf7,0xef,0xdf,0xbf,0x7f};
unsigned char tempdata[8];
void delay(unsigned int t);
void Display(unsigned char FirstBit,unsigned char Num);
main()
while(1)
unsigned int numA=999;
unsigned int j;
j++;
if(j==10)
j=0;
if(numA>0)
numA--;
else
numA=999;
if(numA<100)
tempdata[0]=0;
else
tempdata[0]=dofly_DuanMa[numA/100];
if(numA<10)
tempdata[1]=0;
else
tempdata[1]=dofly_DuanMa[(numA%100)/10];
tempdata[2]=dofly_DuanMa[(numA%100)%10];
Display(0,3);
while(--t);
void deplay(unsigned char FirstBit,unsigned char Num)
unsigned char i;
for(i=0;i<Num;i++)
DataPort=0;
LATCH1=1;
LATCH1=0;
DataPort=dofly_WeiMa[i+FirstBit];
LATCH2=1;
LATCH2=0;
DataPort=tempdata[i];
LATCH1=1;
LATCH2=0;
delay(200);
