[产品供应] 手机电容屏触摸IC CY8C21434 特价优惠,欢迎订购
1272|0
 楼主| szjlj168 发表于 2013-9-17 17:25 | 显示全部楼层 |阅读模式
采购:10000PCS,单价:4.3,欢迎广大客户前来采购.
详细说明:Cypess CY8C21434 电容式触摸按键代码。 提供独立背光LED。 提供直观的代码, 8个触摸按键, 9个LED灯. 触摸芯片为CY8C21434 编译器PSoC Designer V4.4 按如下顺序配置 Cypress 芯片一般不会有问题. 1. 配置MCU 2. 配置EzI2Cs 3. 配置CSD 4. 配置其它, 如Timer等 5. 配置LED灯 配置完成后可以浏览一下引脚分配情况, 被配置的引脚都应该有具体的名称,-Cypess CY8C21434 capacitance touch key code. Provide independent backlight LED. Provides intuitive code, eight touch keys, LED lights 9. Touch chip for CY8C21434 Compiler PSoC Designer, becomes V4.4 Cypress chip in the following order configuration is generally not a problem. A. Configure the MCU (2) configuration EzI2Cs (3) configure the CSD Configure the other, such as Timer 5 configuration LED lights After the configuration, you can browse the pin distribution Pin configuration should have a specific name,
个人签名:深圳永晟达电子科技有限公司专业代理:CYPRESS,Microchip,NXP,ST,ATMEL,TI,LTC,等系列原装进口IC 可代客户开发程序  QQ;547838378
4395
