出现如下错误不知如何解决
1416|6
 楼主| 宋倩2010 发表于 2013-9-17 20:31 | 显示全部楼层 |阅读模式
TE, RAM, area, lm, ge
PSOC EXPRESS
Linking..
LMM info: area 'InterruptRAM' uses 8 bytes in SRAM page 0
LMM info: area 'virtual_registers' uses 8 bytes in SRAM page 0
LMM info: area 'data' item of 4 bytes allocated in SRAM page 0
LMM info: area 'data' item of 2 bytes allocated in SRAM page 0
LMM info: area 'data' item of 1 bytes allocated in SRAM page 0
!ERROR boot.asm[line number unavailable] undefined symbol '__bss_end'
!ERROR boot.asm[line number unavailable] undefined symbol '__ramareas_end'
!ERROR boot.asm[line number unavailable] undefined symbol '__data_end'
C:\PROGRA~1\CYPRES~1\Common\CYPRES~1\tools\make: *** [output/Basic1.rom] Error 1
Basic1 - 4 error(s) 5 warning(s) 01:34:33
chenho 发表于 2013-9-17 20:33 | 显示全部楼层
错误不少啊
gongche 发表于 2013-9-17 20:34 | 显示全部楼层
用到的参数没有定义
huwr 发表于 2013-9-17 20:36 | 显示全部楼层
楼主用designer比较好
huanghuac 发表于 2013-9-17 20:38 | 显示全部楼层
楼主用designer比较好
是啊
 楼主| 宋倩2010 发表于 2013-9-17 20:40 | 显示全部楼层
哦,好吧
kk5290122 发表于 2013-9-17 23:01 | 显示全部楼层
就是呀……lz怎么用的Express呢???PSOC1的话一般用Designer,其他用Creator就行了…………
