[产品供应]
21毫欧1W取样电阻
1266|0
xfychina|  楼主 | 2013-9-30 16:30 | 只看该作者 回帖奖励 |倒序浏览 |阅读模式
21毫欧电阻,21毫欧取样电阻,0.021欧采样电阻
型号
2512SR021FT
阻值
0.021Ω
精度
±1%
封装尺寸
2512
温度系数
±50 ppm
功率
2W
温度范围
-55~+170℃
其它规格毫欧贴片电阻大量供应:
毫欧电阻尺寸:1206:3.2×1.6;2512:6.4×3.2; 2725:7.2×6.4;
毫欧电阻精度:±1%(百分之一精度);±5%(百分之五精度)
毫欧电阻功率:1W;1.5W;2W;3W;4W ;6W
其它阻值毫欧贴片电阻大量推荐:
0.001欧电阻,0.002欧电阻,0.003欧电阻,0.004欧电阻,0.005欧电阻,0.006欧电阻,0.007欧电阻,0.008欧电阻,0.009欧电阻,0.010欧电阻,0.011欧 电阻,0.012欧电阻,0.013欧电阻,0.014欧电阻,0.015欧电阻,0.016欧电阻,0.017欧电阻,0.018欧电阻,0.019欧电阻,0.020欧电阻
其它规格合金大功率贴片电阻查询:http://sh.vk-dz.com/cpcx.asp
其它规格大功率电阻查询:http://www.vk-dz.com/tr.asp  http://gl.87ic.com
