[微控制器/MCU] lpc4337+fatfs+spifi 文件系统变量被修改的问题
2080|0
 楼主| wangxiaofei6485 发表于 2013-10-8 19:25 | 显示全部楼层 |阅读模式
最近在调试LPC4337+FATFS,FLASH用的是MX25L512,但是读写一直不成功。通过Debug监视一个局部变量,发现FATFS文件系统其在一个毫不相干的判断语句后,其值被修改了。
        if (fp->flag & FA__ERROR) return FR_INT_ERR;
上面的代码就是执行后被监视的局部变量值发生变化的语句。在注释后发现其下一条语句依然会把监视的值改掉。
是栈出了问题么?
部分MAP文件:Memory Map of the image
  Image Entry point : 0x1a000115
  Load Region LR_IROM1 (Base: 0x1a000000, Size: 0x00008150, Max: 0x00080000, ABSOLUTE, COMPRESSED[0x0000802c])
    Execution Region RW_IRAM1 (Base: 0x10000000, Size: 0x00000c00, Max: 0x00008000, ABSOLUTE)
    Base Addr    Size         Type   Attr      Idx    E Section Name        Object
    0x10000000   0x00000c00   Zero   RW         8448    .bss                endpoint.o
    Execution Region RW_RAM3 (Base: 0x10080000, Size: 0x00003200, Max: 0x0000a000, ABSOLUTE)
    0x10080000   0x00003200   Zero   RW         1524    .bss                board_keil_mcb_18574357.o
    Execution Region ER_IROM1 (Base: 0x1a000000, Size: 0x00008000, Max: 0x00080000, ABSOLUTE)
    Execution Region RW_IRAM2 (Base: 0x20000000, Size: 0x00008cc8, Max: 0x00010000, ABSOLUTE, COMPRESSED[0x0000002c])
    0x20000000   0x00000018   Data   RW          421    .data               generichid.o
    0x20000018   0x00000010   Data   RW         1117    .data               drv_lpc43xx.o
    0x20000028   0x00000081   Data   RW         1526    .data               board_keil_mcb_18574357.o
    0x200000a9   0x00000003   PAD
    0x200000ac   0x0000003c   Data   RW         5262    .data               tasks.o
    0x200000e8   0x0000000e   Data   RW         8211    .data               usbtask.o
    0x200000f6   0x00000003   Data   RW         8382    .data               devicestandardreq.o
    0x200000f9   0x00000003   PAD
    0x200000fc   0x00000034   Data   RW         8449    .data               endpoint.o
    0x20000130   0x00000003   Data   RW         8627    .data               usbcontroller.o
    0x20000133   0x00000002   Data   RW         8682    .data               hal_lpc18xx.o
    0x20000135   0x00000001   PAD
    0x20000136   0x00000011   Data   RW         9109    .data               mrfi.o
    0x20000147   0x00000001   PAD
    0x20000148   0x00000006   Data   RW         9594    .data               ff.o
    0x2000014e   0x00000002   PAD
    0x20000150   0x0000003f   Zero   RW          420    .bss                generichid.o
    0x2000018f   0x00000001   PAD
    0x20000190   0x000000fc   Zero   RW         5261    .bss                tasks.o
    0x2000028c   0x0000026c   Zero   RW         7880    .bss                lpc18xx_43xx_emac.o
    0x200004f8   0x00000308   PAD
    0x20000800   0x000012b0   Zero   RW         8825    .bss                endpoint_lpc18xx.o
    0x20001ab0   0x00000014   Zero   RW         8989    .bss                mx25l1606edrv.o
    0x20001ac4   0x00000203   Zero   RW         9107    .bss                mrfi.o
    0x20001cc7   0x00000001   PAD
    0x20001cc8   0x00007000   Zero   RW         1404    STACK               keil_freertos_startup_lpc18xx43xx.o
  Load Region LR_IROM2 (Base: 0x1b000000, Size: 0x0002acc8, Max: 0x00080000, ABSOLUTE)
    Execution Region ER_IROM2 (Base: 0x1b000000, Size: 0x0002acc8, Max: 0x00080000, ABSOLUTE)
    0x1b000000   0x0002acc8   Data   RO         9844    .constdata          cc936.o
      Code (inc. data)   RO Data    RW Data    ZI Data      Debug   Library Member Name
        92          0          0          0          0          0   __dczerorl2.o
         0          0          0          0          0          0   entry.o
         0          0          0          0          0          0   entry10a.o
         0          0          0          0          0          0   entry11a.o
         8          4          0          0          0          0   entry2.o
         4          0          0          0          0          0   entry5.o
         0          0          0          0          0          0   entry7b.o
         0          0          0          0          0          0   entry8b.o
         8          4          0          0          0          0   entry9a.o
        30          0          0          0          0          0   handlers.o
        36          8          0          0          0         68   init.o
        30          0          0          0          0         68   llshl.o
        32          0          0          0          0         68   llushr.o
        36          0          0          0          0         68   memcpya.o
        36          0          0          0          0        108   memseta.o
      1150         54          0          0          0        352   printf8.o
        98          0          0          0          0         92   uldiv.o
       160         26          0          0          0         92   amic.o
       276         24         64          0          0         96   atmel.o
       220         26          0          0          0         88   chi.o
       184         12          0          0          0         96   eon.o
       188         24          0          0          0         96   esmt.o
       352         44          0          0          0        232   falcon_details.o
       176         20          0          0          0         96   giga.o
       404         28        130          0          0         92   macronix.o
       376         40          0          0          0        184   numonyx.o
       236         24          0          0          0        112   spansion.o
      4848        116         84          0          0       1148   spifi_rom_api.o
       184         26        120          0          0         88   sst.o
       252         20          0          0          0        172   winbond.o
      9418        500        400          0          0       3416   Library Totals
         2          0          2          0          0          0   (incl. Padding)
      Code (inc. data)   RO Data    RW Data    ZI Data      Debug   Library Name
      1560         70          0          0          0        824   mc_w.l
      7856        430        398          0          0       2592   spifi_drv_M4.lib
     31100       1804     176972        336      51576     423473   Grand Totals
     31100       1804     176972         44      51576     423473   ELF Image Totals (compressed)
     31100       1804     176972         44          0          0   ROM Totals
    Total RO  Size (Code + RO Data)               208072 ( 203.20kB)
    Total RW  Size (RW Data + ZI Data)             51912 (  50.70kB)
    Total ROM Size (Code + RO Data + RW Data)     208116 ( 203.24kB)
