[产品供应]
25毫欧2W取样电阻
1156|0
xfychina|  楼主 | 2013-10-9 13:46 | 只看该作者 回帖奖励 |倒序浏览 |阅读模式
25毫欧电阻,25毫欧取样电阻,25mΩ大功率采样电阻
型号
2512SR025FT
阻值
0.025Ω
精度
±1%
封装尺寸
2512
温度系数
±50 ppm
功率
2W
温度范围
-55~+170℃
其它规格毫欧贴片电阻大量供应:
毫欧电阻尺寸:1206:3.2×1.6;2512:6.4×3.2; 2725:7.2×6.4;
毫欧电阻精度:±1%(百分之一精度);±5%(百分之五精度)
毫欧电阻功率:1W;1.5W;2W;3W;4W ;6W
其它阻值毫欧贴片电阻大量推荐:
0.01R,0.02R,0.03R,0.04R,0.05R,0.06R,0.07R,0.08R,0.09R,0.1R,0.12R,0.13R,0.14R,0.15R,0.16R,0.17R,0.18R,0.19R,0.2R0.001R,0.002R,0.003R,0.004R,0.005R,0.006R,0.007R,0.008R,0.009R,0.010R,0.011R,0.012R,0.013R,0.014R,0.015R,0.016R,0.017R,0.018R,0.019R,0.020R,0.021R,0.022R,0.023R,0.024R,0.025R,0.026R,0.027R,0.028R,0.029R,0.030R,0.031R,0.032R,0.033R,0.034R,0.035R,0.036R
其它规格合金大功率贴片电阻查询:http://sh.vk-dz.com/cpcx.asp
其它规格大功率电阻查询:http://www.vk-dz.com/tr.asp  http://gl.87ic.com
