DeviceIoControl向虚拟U盘写数据失败的问题
3733|0
 楼主| elego 发表于 2013-10-15 14:28 | 显示全部楼层 |阅读模式
写64字节以下可以,超过64字节就返回121L(0x79)的错误.
查看该错误的定义,如下:
"#define ERROR_SEM_TIMEOUT                121L"
操作代码如下:
BOOL CIOCtrlHelper::CDBWriteData(HANDLE hDevice, BYTE *pDataBuffer, long nBufLen)
ULONG returned,length;
DWORD dwErrCode;
BOOL status;
ASSERT(pDataBuffer);
SCSI_PASS_THROUGH_DIRECT_WITH_BUFFER sptdwb;
    ZeroMemory(&sptdwb,sizeof(SCSI_PASS_THROUGH_DIRECT_WITH_BUFFER));
    sptdwb.sptd.Length    = sizeof(SCSI_PASS_THROUGH_DIRECT);
    sptdwb.sptd.PathId    = 0;
    sptdwb.sptd.TargetId   = 1;
    sptdwb.sptd.Lun     = 0;
    sptdwb.sptd.CdbLength   = IOCTRL_CDB_LEN;
    sptdwb.sptd.SenseInfoLength  = 14;
    sptdwb.sptd.DataIn    = SCSI_IOCTL_DATA_OUT;
    sptdwb.sptd.DataTransferLength = nBufLen;
    sptdwb.sptd.TimeOutValue  = IOCTRL_TIMEOUT_VALUE;
    sptdwb.sptd.DataBuffer   = pDataBuffer;
    sptdwb.sptd.SenseInfoOffset =
  offsetof(SCSI_PASS_THROUGH_WITH_BUFFERS,SenseBuf);
memcpy( sptdwb.sptd.Cdb, m_byCDBBuffer, IOCTRL_CDB_LEN );
length = sizeof(SCSI_PASS_THROUGH_DIRECT_WITH_BUFFER);
status = DeviceIoControl(hDevice,
        IOCTL_SCSI_PASS_THROUGH_DIRECT,
                             &sptdwb,
                             length,
                             &sptdwb,
                             length,
                             &returned,
                             NULL);
dwErrCode = GetLastError();
if( dwErrCode == 0x79 ) // Timeout
if( !status )
  return FALSE;
else
  return TRUE;
