[PIC®/AVR®/dsPIC®产品] 关于C语言多文件编译的问题
1650|1
 楼主| sunflower860 发表于 2013-10-19 22:34 | 显示全部楼层 |阅读模式
程序如下:
Main.c文件如下:
#include <pic18.h>
#include "Average.h"
#define uchar unsigned char
#define uint unsigned int
__PROG_CONFIG(1,0x0700);
__PROG_CONFIG(2,0x1f1f);
__PROG_CONFIG(3,0x8100);
__PROG_CONFIG(4,0x0085);
__PROG_CONFIG(5,0x000f);
__PROG_CONFIG(6,0xe00f);
__PROG_CONFIG(7,0x400f);           //设置配置位
volatile uchar AD_Array[10];
volatile uchar Current;
* 函 数 名: main()
* 函数功能: 主函数
* 入口参数: 无
* 返    回: 无
void main()
    while(1)
        Current = AVE_Cal(AD_Array);
Average.c文件如下:
* 函 数 名: AVE_Cal()
* 函数功能: 求平均数
* 入口参数: 求均值数组
* 返    回: 平均值
uchar AVE_Cal(volatile uchar data[])
    uchar i, result;
    uchar sum = data[0];
    for(i=1;i<10;i++)
        sum = sum + data[i];
    result = sum/10;
    return result;
Average.h文件如下:
#ifndef _AVERAGE_H_
#define _AVERAGE_H_
/************************声明函数***********************************************/
#endif
PICC18编译完后报错如下:
Error   [315] D:\2. My Project\19.DIGITAL BATTERY\TT\Main.c; 7.1 "{" expected
Error   [195] D:\2. My Project\19.DIGITAL BATTERY\TT\Main.c; 8.1 expression syntax
Error   [195] D:\2. My Project\19.DIGITAL BATTERY\TT\Main.c; 9.1 expression syntax
Error   [195] D:\2. My Project\19.DIGITAL BATTERY\TT\Main.c; 10.1 expression syntax
Error   [195] D:\2. My Project\19.DIGITAL BATTERY\TT\Main.c; 11.1 expression syntax
Error   [195] D:\2. My Project\19.DIGITAL BATTERY\TT\Main.c; 12.1 expression syntax
Error   [195] D:\2. My Project\19.DIGITAL BATTERY\TT\Main.c; 13.1 expression syntax
Error   [314] D:\2. My Project\19.DIGITAL BATTERY\TT\Main.c; 25.1 ";" expected
Warning [343] D:\2. My Project\19.DIGITAL BATTERY\TT\Main.c; 29.1 implicit return at end of non-void function
Error   [285] D:\2. My Project\19.DIGITAL BATTERY\TT\Main.c; 30.1 no identifier in declaration
Warning [374] D:\2. My Project\19.DIGITAL BATTERY\TT\Main.c; 30.1 missing basic type; int assumed
Error   [314] D:\2. My Project\19.DIGITAL BATTERY\TT\Main.c; 30.1 ";" expected
请各位大仙指正
 楼主| sunflower860 发表于 2013-10-19 23:09 | 显示全部楼层
不好意思,是Average.h文件中的函数声明忘加“;”了。:L
