SPIM 的读操作
1507|5
 楼主| tian111 发表于 2013-10-20 14:10 | 显示全部楼层 |阅读模式
请问有谁调试成功过CY8C21434 SPIM 模块的读操作,我可以向SPI从设备写操作,但是死活都不能进行读操作
chenho 发表于 2013-10-20 14:12 | 显示全部楼层
这么高端
 楼主| tian111 发表于 2013-10-20 14:16 | 显示全部楼层
也没有,我是菜鸟
宋倩2010 发表于 2013-10-20 14:17 | 显示全部楼层
有程序吗?
 楼主| tian111 发表于 2013-10-20 14:20 | 显示全部楼层
void SPI_Write(unsigned char dig)
PRT2DR |= CS;
while(!(SPIM_1_bReadStatus() & SPIM_1_SPIM_TX_BUFFER_EMPTY)){};
PRT2DR &= ~CS;  // set slave select low
SPIM_1_SendTxData(dig); // set message to transmit
while(!(SPIM_1_bReadStatus() & SPIM_1_SPIM_SPI_COMPLETE)){};
PRT2DR |= CS; //
unsigned char SPI_Read(void)
unsigned char ReceivedData;
PRT2DR |= CS;
PRT2DR &= ~CS;
SPIM_1_SendTxData(0x00);  // 写伪数据,以便读到数据
while(!(SPIM_1_bReadStatus() &  SPIM_1_SPIM_RX_BUFFER_FULL));//RX Buffer register has received current data
ReceivedData = SPIM_1_bReadRxData();
PRT2DR |= CS;
return ReceivedData;
gongche 发表于 2013-10-20 14:24 | 显示全部楼层
