STM32 USB串口+U盘的枚资料,只看到U盘
1617|2
 楼主| mfkihc 发表于 2013-10-27 17:06 | 显示全部楼层 |阅读模式
这是我的枚举数据
Device  Phase  Data                      Description       Cmd.Phase.Ofs(rep)
  15.0  CTL    80 06 00 03  00 00 ff 00  GET DESCRIPTOR           1.1.0(2)
  15.0  IN     04 03 09 04               ....                     1.2.0
  15.0  CTL    80 06 02 03  09 04 ff 00  GET DESCRIPTOR           2.1.0(2)
  15.0  IN     18 03 4d 00  61 00 73 00  ..M.a.s.                 2.2.0
               73 00 53 00  74 00 6f 00  s.S.t.o.                 2.2.8
               72 00 61 00  67 00 65 00  r.a.g.e.                 2.2.16
  15.0  CTL    80 06 00 01  00 00 12 00  GET DESCRIPTOR           5.1.0
  15.0  IN     12 01 10 01  00 00 00 40  .......@                 5.2.0
               16 04 11 50  00 00 01 02  ...P....                 5.2.8
               01 01                     ..                       5.2.16
  15.0  CTL    80 06 00 02  00 00 09 00  GET DESCRIPTOR           6.1.0
  15.0  IN     09 02 59 00  03 01 00 c0  ..Y.....                 6.2.0
               32                        2                        6.2.8
  15.0  CTL    80 06 00 02  00 00 59 00  GET DESCRIPTOR           7.1.0
  15.0  IN     09 02 59 00  03 01 00 c0  ..Y.....                 7.2.0
               32 09 04 00  00 02 08 05  2.......                 7.2.8
               50 00 07 05  82 02 40 00  P.....@.                 7.2.16
               00 07 05 03  02 40 00 00  .....@..                 7.2.24
               09 04 01 00  01 02 02 01  ........                 7.2.32
               00 05 24 00  10 01 05 24  ..$....$                 7.2.40
               01 00 01 04  24 02 00 05  ....$...                 7.2.48
               24 06 00 01  07 05 84 03  $.......                 7.2.56
               40 00 01 09  04 02 00 02  @.......                 7.2.64
               0a 00 00 00  07 05 82 02  ........                 7.2.72
               40 00 00 07  05 03 02 40  @......@                 7.2.80
               00                        .                        7.2.88
  15.0  CTL    00 09 01 00  00 00 00 00  SET CONFIG               8.1.0
  15.0  CTL    80 06 00 03  00 00 ff 00  GET DESCRIPTOR           9.1.0(8)
  15.0  IN     04 03 09 04               ....                     9.2.0
  15.0  CTL    80 06 02 03  09 04 ff 00  GET DESCRIPTOR          10.1.0(8)
  15.0  IN     18 03 4d 00  61 00 73 00  ..M.a.s.                10.2.0
               73 00 53 00  74 00 6f 00  s.S.t.o.                10.2.8
               72 00 61 00  67 00 65 00  r.a.g.e.                10.2.16
  15.0  CTL    80 06 00 01  00 00 12 00  GET DESCRIPTOR          25.1.0
  15.0  IN     12 01 10 01  00 00 00 40  .......@                25.2.0
               16 04 11 50  00 00 01 02  ...P....                25.2.8
               01 01                     ..                      25.2.16
  15.0  CTL    80 06 00 02  00 00 09 00  GET DESCRIPTOR          26.1.0
  15.0  IN     09 02 59 00  03 01 00 c0  ..Y.....                26.2.0
               32                        2                       26.2.8
  15.0  CTL    80 06 00 02  00 00 59 00  GET DESCRIPTOR          27.1.0
  15.0  IN     09 02 59 00  03 01 00 c0  ..Y.....                27.2.0
               32 09 04 00  00 02 08 05  2.......                27.2.8
               50 00 07 05  82 02 40 00  P.....@.                27.2.16
               00 07 05 03  02 40 00 00  .....@..                27.2.24
               09 04 01 00  01 02 02 01  ........                27.2.32
               00 05 24 00  10 01 05 24  ..$....$                27.2.40
               01 00 01 04  24 02 00 05  ....$...                27.2.48
               24 06 00 01  07 05 84 03  $.......                27.2.56
               40 00 01 09  04 02 00 02  @.......                27.2.64
               0a 00 00 00  07 05 82 02  ........                27.2.72
               40 00 00 07  05 03 02 40  @......@                27.2.80
               00                        .                       27.2.88
  15.0  CTL    00 09 01 00  00 00 00 00  SET CONFIG              28.1.0
  15.0  CTL    80 06 00 03  00 00 ff 00  GET DESCRIPTOR          29.1.0(6)
  15.0  IN     04 03 09 04               ....                    29.2.0
  15.0  CTL    80 06 02 03  09 04 ff 00  GET DESCRIPTOR          30.1.0(6)
  15.0  IN     18 03 4d 00  61 00 73 00  ..M.a.s.                30.2.0
               73 00 53 00  74 00 6f 00  s.S.t.o.                30.2.8
               72 00 61 00  67 00 65 00  r.a.g.e.                30.2.16
黄小俊 发表于 2013-10-27 21:31 | 显示全部楼层
香水城 发表于 2013-10-28 14:35 | 显示全部楼层
PID、VID改一下,或者scan for hardware change。
其实,类似的问题,论坛里搜索一下就可以找到~~~
啊?已经结贴了?好吧
