初学MSP430,遇到问题了
1537|2
huigoushang|  楼主 | 2013-10-29 00:07 | 只看该作者 回帖奖励 |倒序浏览 |阅读模式
运行#include  <msp430.h>
#include  "Cry1602.h"
#include  "Cry1602.c"
uchar *s1 = "welcome!";
void main( void )
    /*下面六行程序关闭所有的IO口*/
    P1DIR = 0XFF;P1OUT = 0XFF;
    P2DIR = 0XFF;P2OUT = 0XFF;
    P3DIR = 0XFF;P3OUT = 0XFF;
    P4DIR = 0XFF;P4OUT = 0XFF;
    P5DIR = 0XFF;P5OUT = 0XFF;
    P6DIR = 0XFF;P6OUT = 0XFF;
    uchar i;
    WDTCTL = WDT_ADLY_250;               //间隔定时器,定时16ms
   // P6DIR |= BIT2;P6OUT |= BIT2;         //关闭电平转换
    LcdReset();
    DispStr(4,0,s1);
    LocateXY(0,9);                      //确定写入字符的显示位置
    LcdWriteCommand(0x07, 1);           //整体显示左移
    for(i = 12; i > 0; i--)
        LcdWriteData(0x20);
        //延时250ms
        IFG1 &= ~WDTIFG;
        while(!(IFG1 & WDTIFG));
        IFG1 &= ~WDTIFG;
    while(1)
        LcdWriteCommand(0x05, 1);           //整体显示右移
        for(i = 24; i > 0; i--)
            LcdWriteData(0x20);
            //延时250ms
            IFG1 &= ~WDTIFG;
            IFG1 &= ~WDTIFG;
            LcdWriteData(0x20);
            //延时250ms
            IFG1 &= ~WDTIFG;
            IFG1 &= ~WDTIFG;
huigoushang|  楼主 | 2013-10-29 00:08 | 只看该作者
代码时出现如下错误
Error[e27]: Entry "Delay5ms" in module cry1602 ( D:\MSP430_WorkSpace\test2\Debug\Obj\cry1602.r43 ) redefined in module main ( D:\
MSP430_WorkSpace\test2\Debug\Obj\main.r43 )
Error while running Linker
,,求告诉
dirtwillfly| | 2013-10-29 11:20 | 只看该作者
貌似Delay5ms重复定义了。
你的 "Cry1602.h"和 "Cry1602.c"两个文件里的代码是怎么样的?
