C2000无法仿真
1282|2
 楼主| jinpaidianzi 发表于 2013-10-31 00:01 | 显示全部楼层 |阅读模式
Error connecting to the target:
(Error -151 @ 0x0)
One of the FTDI driver functions used during
the connect returned bad status or an error.
The cause may one or more of: invalid emulator serial number,
blank emulator EEPROM, missing FTDI drivers, faulty USB cable.
Use the xds100serial command-line utility in the 'common/uscif'
folder to verify the emulator can be located.
(Emulation package 5.1.73.0)
 楼主| jinpaidianzi 发表于 2013-10-31 00:02 | 显示全部楼层
难不成是驱动的事?
拿起书本 发表于 2013-10-31 09:27 | 显示全部楼层
CCS里测试目标连接可以吗?或才重新安装一次
