求一个定时器B的pwm例程
1454|4
teabottle|  楼主 | 2013-10-31 00:19 | 只看该作者 回帖奖励 |倒序浏览 |阅读模式
谁有分享一下吧
zuomujie| | 2013-11-1 22:45 | 只看该作者
//  MSP430F54x Demo - Timer_B, Toggle P1.0, Overflow ISR, 32kHz ACLK
//  Description: Toggle P1.0 using software and the Timer_B overflow ISR.
//  In this example an ISR triggers when TB overflows. Inside the ISR P1.0
//  is toggled. Toggle rate is exactly 0.25Hz = [32kHz/FFFFh]/2. Proper use of the
//  TBIV interrupt vector generator is demonstrated.
//  ACLK = TBCLK = 32kHz, MCLK = SMCLK = default DCO ~ 1.045MHz
//           MSP430F5438
//      --|RST            |
//        |           P1.0|-->LED
//   M Smertneck / W. Goh
//   Texas Instruments Inc.
//   September 2008
//   Built with CCE Version: 3.2.2 and IAR Embedded Workbench Version: 4.11B
#include "msp430x54x.h"
void main(void)
  WDTCTL = WDTPW + WDTHOLD;                 // Stop WDT
  P1DIR |= 0x01;                            // Set P1.0 to output direction
  TBCTL = TBSSEL_1 + MC_2 + TBCLR + TBIE;   // ACLK, contmode, clear TBR,
                                            // enable interrupt
  __bis_SR_register(LPM3_bits + GIE);       // Enter LPM3, enable interrupts
  __no_operation();                         // For debugger
// Timer_B7 Interrupt Vector (TBIV) handler
#pragma vector=TIMERB1_VECTOR
__interrupt void TIMERB1_ISR(void)
  /* Any access, read or write, of the TBIV register automatically resets the
  highest "pending" interrupt flag. */
  switch( __even_in_range(TBIV,14) )
    case  0: break;                          // No interrupt
    case  2: break;                          // CCR1 not used
    case  4: break;                          // CCR2 not used
    case  6: break;                          // CCR3 not used
    case  8: break;                          // CCR4 not used
    case 10: break;                          // CCR5 not used
    case 12: break;                          // CCR6 not used
    case 14: P1OUT ^= 0x01;                  // overflow
            break;
    default: break;
1988020566| | 2013-11-2 19:41 | 只看该作者
哪个芯片的?
1988020566| | 2013-11-2 19:42 | 只看该作者
一般在ti官网就有现成的程序的。自己修改一下就行的。
