老师布置的题:
这是我写的代码:
library ieee;
use ieee.std_logic_1164.all;
use ieee.std_logic_arith.all;
use ieee.std_logic_unsigned.all;
entity ppm is
port(
din: in std_logic_vector(7 downto 0);
le: in std_logic;
clk: in std_logic;
rst: in std_logic;
al: out std_logic;
outdata: out std_logic
end entity ppm;
architecture ppm1 of ppm is
type st is(idle,s1,s2,s3,s4,s5,s6,s7);
signal state: st;
signal counter0: std_logic_vector(2 downto 0);
signal counter1: std_logic_vector(6 downto 0);
signal dinbuf: std_logic_vector(7 downto 0);
signal regQ: std_logic_vector(1 downto 0);
signal outdatabuf: std_logic;
begin
processcount: process(clk) is
begin
if clk'event and clk='0' then
if state/=idle then
if counter1="1111111" then
counter1<="0000000";
counter0<=counter0+"001";
else
counter1<=counter1+"0000001";
end if;
else
counter0<="000";
end if;
end if;
end process;
processdinbuf: process(state) is
begin
if state=s1 then
dinbuf<=din;
else
dinbuf<="00000000";
end if;
end process;
processregQ: process(counter0) is
begin
case counter0 is
when "000"=>
regQ(0)<=dinbuf(1);
regQ(1)<=dinbuf(0);
when "001"=>
regQ(0)<=dinbuf(3);
regQ(1)<=dinbuf(2);
when "010"=>
regQ(0)<=dinbuf(5);
regQ(1)<=dinbuf(4);
when "011"=>
regQ(0)<=dinbuf(7);
regQ(1)<=dinbuf(6);
when others=>regQ<="00";
end case;
end process;
processal: process(state) is
begin
case state is
when idle=>al<='0';
when s1|s2|s3|s4|s5|s6=>al<='1';
when others=>al<='0';
end case;
end process;
processst: process(clk) is
begin
if clk'event and clk='1' then
if rst='0' then
dinbuf<="00000000";
counter0<="000";
regQ<="00";
al<='0';
outdata<='0';
state<=idle;
else
case state is
when idle=>
if le='0' then
state<=idle;
else
state<=s1;
end if;
when s1=>
if counter1<"1111111" then
state<=s1;
else
case regQ is
when "00"=>state<=s2;
when "01"=>state<=s3;
when "10"=>state<=s4;
when "11"=>state<=s5;
when others=>state<=idle;
end case;
end if;
when s2=>
state<=s2;
elsif counter0="100" then
state<=s6;
else
case regQ is
end case;
end if;
when s3=>
state<=s3;
state<=s6;
else
case regQ is
when others=>state<=s6;
end case;
end if;
when s4=>
state<=s4;
state<=s6;
else
case regQ is
end case;
end if;
when s5=>
state<=s5;
state<=s6;
else
case regQ is
end case;
end if;
when s6=>
state<=s6;
else
state<=idle;
end if;
when others=>
state<=idle;
end case;
end if;
end if;
end process;
processout: process(state,counter1) is
begin
case state is
when idle=>
outdatabuf<='0';
when s1=>
if counter1<="0001111" then
outdatabuf<='0';
elsif counter1>"0001111" and counter1<="1000111" then
outdatabuf<='1';
elsif counter1>"1000111" and counter1<="1001111" then
outdatabuf<='0';
else
outdatabuf<='1';
end if;
when s2=>
outdatabuf<='1';
elsif counter1>"0001111" and counter1<="0011111" then
outdatabuf<='0';
else
outdatabuf<='1';
end if;
when s3=>
if counter1<="0100001" then
outdatabuf<='1';
elsif counter1>"0100001" and counter1<="0111111" then
outdatabuf<='0';
else
outdatabuf<='1';
end if;
when s4=>
if counter1<="1001111" then
outdatabuf<='1';
elsif counter1>"1001111" and counter1<="1011111" then
outdatabuf<='0';
else
outdatabuf<='1';
end if;
when s5=>
if counter1<="1101111" then
outdatabuf<='1';
else
outdatabuf<='0';
end if;
when s6=>
if counter1<="0011111" then
outdatabuf<='1';
elsif counter1>"0011111" and counter1<="0101111" then
outdatabuf<='0';
elsif counter1>"0101111" and counter1<="0111111" then
outdatabuf<='1';
else
outdatabuf<='0';
end if;
when others=>
outdatabuf<='0';
end case;
end process;
outt: process(clk) is
begin
outdata<=outdatabuf;
end if;
end process;
end architecture ppm1;
这是测试代码:
library ieee;
entity ppm_test is
end entity;
architecture ppm_test1 of ppm_test is
component ppm is
port(
le: in std_logic;
clk: in std_logic;
rst: in std_logic;
al: out std_logic;
end component ppm;
signal clk1: std_logic;
signal din1: std_logic_vector(7 downto 0);
signal rst1: std_logic;
signal le1: std_logic;
signal al1: std_logic;
signal outdata1: std_logic;
begin
ppmm: ppm port map(clk=>clk1,din=>din1,rst=>rst1,le=>le1,al=>al1,outdata=>outdata1);
process
begin
clk1<='0';
wait for 50ns;
clk1<='1';
wait for 50ns;
end process;
process
begin
rst1<='1';
le1<='0';
din1<="00000000";
wait for 180ns;
rst1<='0';
wait for 100ns;
rst1<='1';
wait for 100ns;
le1<='1';
din1<="11100001";
wait for 100ns;
le1<='0';
din1<="00000000";
wait for 10ms;
end process;
end architecture;
这是仿真图:
我现在特别想知道为什么计数器counter1不工作,还有握手信号al为什么状态机一进s1就立刻变成x;
这是modelsim仿真是说的:# ** Warning: There is an 'U'|'X'|'W'|'Z'|'-' in an arithmetic operand, the result will be 'X'(es).# Time: 500 ns Iteration: 2 Instance: /ppm_test/ppmm
# Time: 550 ns Iteration: 1 Instance: /ppm_test/ppmm
# Time: 550 ns Iteration: 2 Instance: /ppm_test/ppmm
# Time: 600 ns Iteration: 1 Instance: /ppm_test/ppmm
# Time: 600 ns Iteration: 2 Instance: /ppm_test/ppmm
# Time: 650 ns Iteration: 1 Instance: /ppm_test/ppmm
# Time: 700 ns Iteration: 1 Instance: /ppm_test/ppmm
求各位大牛帮忙啊,以前没用过vhdl,就上课时学了几天,先谢谢了
