[产品供应] 28毫欧3W取样电阻
1201|0
 楼主| xfychina 发表于 2013-11-6 18:38 | 显示全部楼层 |阅读模式
28毫欧电阻,28毫欧合金电阻,0.028欧电阻
型号
2512RR028FT
阻值
0.028Ω
精度
±1%
封装尺寸
2512
温度系数
±50 ppm
功率
3W
温度范围
-55~+170℃
其它规格毫欧电阻大量供应:
毫欧电阻尺寸:1206:3.2×1.6;2512:6.4×3.2; 2725:7.2×6.4;
毫欧电阻精度:±1%(百分之一精度);±5%(百分之五精度)
毫欧电阻功率:1W;1.5W;2W;3W;4W ;6W
热销阻值毫欧电阻推荐:
0.033欧电阻,0.034欧电阻,0.035欧电阻,0.036欧电阻,0.037欧电阻,0.038欧电阻,0.039欧电阻,0.040欧电阻,0.041欧电阻,0.042欧电 阻,0.043欧电阻,0.044欧电阻,0.045欧电阻,0.046欧电阻,0.047欧电阻,0.048欧电阻,0.049欧电阻,0.050欧电阻,0.051欧电阻,0.052欧电阻,0.053 欧电阻,0.054欧电阻,0.055欧电阻,0.056欧电阻
其它规格低阻大功率采样电阻查询:http://sh.vk-dz.com/cpcx.asp
其它规格晶圆电阻查询:http://www.vk-dz.com/csr.asp   http://csr.87ic.com
