[产品供应] 29毫欧2W取样电阻
1077|0
 楼主| xfychina 发表于 2013-11-6 18:41 | 显示全部楼层 |阅读模式
0.029欧电阻,29mΩ采样电阻,29毫欧分流电阻
型号
2512SR029FT
阻值
0.029Ω
精度
±1%
封装尺寸
2512
温度系数
±50 ppm
功率
2W
温度范围
-55~+170℃
其它规格毫欧电阻大量供应:
毫欧电阻尺寸:1206:3.2×1.6;2512:6.4×3.2; 2725:7.2×6.4;
毫欧电阻精度:±1%(百分之一精度);±5%(百分之五精度)
毫欧电阻功率:1W;1.5W;2W;3W;4W ;6W
热销阻值毫欧电阻推荐:
0.057欧电阻,0.058欧电阻,0.059欧电阻,0.060欧电阻,0.061欧电阻,0.062欧电阻,0.063欧电 阻,0.064欧电阻,0.065欧电阻,0.066欧电阻,0.067欧电阻,0.068欧电阻,0.069欧电阻,0.070欧电阻,0.071欧电阻,0.072欧电阻,0.073欧电阻,0.074 欧电阻,0.075欧电阻,0.076欧电阻,0.077欧电阻,0.078欧电阻,0.079欧电阻,0.080欧电阻,0.081欧电阻,0.082欧电阻
其它规格低阻大功率采样电阻查询:http://sh.vk-dz.com
更多规格精密电阻查询请登录:http://www.vk-dz.com/viking.asp  http://ar.87ic.com
