ARM
1250|0
 楼主| xiachu 发表于 2013-11-14 17:49 | 显示全部楼层 |阅读模式
#include "inc/hw_ints.h"
#include "inc/hw_memmap.h"
#include "inc/hw_types.h"
#include "driverlib/gpio.h"
#include "driverlib/sysctl.h"
#define PINS GPIO_PIN_6
void delay(int d)
        for(;d;--d);
void SysCtlClockSet(unsigned long ulConfig)
void   SysCtlPeripheralEnable (unsigned long ulPeripheral)
void GPIODirModeSet(unsigned long ulPort,unsigned char ucPins,unsigned long ulPinIO)
void GPIOPinWrite(unsigned long ulPort, unsigned char ucPins, unsigned char ucVal)
int main(void)
        unsigned int i;
          SysCtlClockSet(SYSCTL_SYSDIV_1|SYSCTL_USE_OSC|SYSCTL_OSC_MAIN|SYSCTL_XTAL_6MHZ);//直接使用外部晶振
          SysCtlPeripheralEnable(SYSCTL_PERIPH_GPIOB);//使能GPIO的PB模块
          GPIODirModeSet(GPIO_PORTB_BASE,PINS,GPIO_DIR_MODE_OUT);//设置PB6输出
          for(i=0;i<10;i++)
                  GPIOPinWrite(GPIO_PORTB_BASE,PINS,~PINS);//置PB6低电平
                  delay(20000);
                  GPIOPinWrite(GPIO_PORTB_BASE,PINS,PINS);//置PB6高电平
                  delay(20000);
          SysCtlClockSet(SYSCTL_SYSDIV_1|SYSCTL_USE_PLL|SYSCTL_OSC_MAIN|SYSCTL_XTAL_6MHZ);//使用PLL
          for(i=0;i<10;i++)
          {GPIOPinWrite(GPIO_PORTB_BASE,PINS,~PINS);
          delay(20000);
          delay(20000);
          return 0;
用的CCSV5 单步执行能执行,但是发现相应的管脚寄存器数据不改变一直是0xBAD0BAD0  而且没有使能的GPIO A C D模块能看到数据~按理说我没有使能的模块 应该显示 cant read   求指导
向0x20000000写入数据时  数据能正确写入
