PIC18刚学mplab 等大家帮我看看我的code
1310|0
 楼主| tonyxrc 发表于 2013-11-16 13:33 | 显示全部楼层 |阅读模式
需要写个想超市电动门一样的code
int main (void)
   TRISD=0;
   TRISB=1;
   unsigned int i;
while (1)
   if ((RB4==1) ||(RB5==1))      //RB4=motion sensor and RB5=door fully closed
       i=1;
   else if (RB2==1)              //rb2=door fully open 1
       i=0;
   while ((i==1) && (RB2==0))  //rb2=door fully open 0
           RD3=1;  //motor door open
          RD3=0;
   while ((i==0)&&(RB5==0)) //RB0=doorclosed
       RD2=1;     //motor door close
   RD2=0;
   return (0);
问题是当第2个while loop出不来了一直在RD2=1, 当RB5=1马达就不动了,放开就继续转。我希望的是能回到第一行的if RB4在给个1 继续在loop 一般。新手请大家指教指教
