问题解决了,这几天没顾上回帖子……
先贴代码- void spi2_init(void)
- GPIO_InitTypeDef GPIO_conf;
- SPI_InitTypeDef SPI_conf;
- //////////////////////////////////////////////////////////////clock
- RCC_APB1PeriphClockCmd(RCC_APB1Periph_SPI2,ENABLE);
- RCC_AHB1PeriphClockCmd(RCC_AHB1Periph_GPIOA,ENABLE);
- RCC_AHB1PeriphClockCmd(RCC_AHB1Periph_GPIOB,ENABLE);
- RCC_AHB1PeriphClockCmd(RCC_AHB1Periph_GPIOC,ENABLE);
- ////////////////////////////////////////////////////////////// I/O Init
- GPIO_PinAFConfig(GPIOB,GPIO_PinSource12,GPIO_AF_SPI2);
- GPIO_PinAFConfig(GPIOB,GPIO_PinSource13,GPIO_AF_SPI2);
- GPIO_PinAFConfig(GPIOB,GPIO_PinSource14,GPIO_AF_SPI2);
- GPIO_PinAFConfig(GPIOB,GPIO_PinSource15,GPIO_AF_SPI2);
- GPIO_conf.GPIO_Mode=GPIO_Mode_AF;
- GPIO_conf.GPIO_OType=GPIO_OType_PP ;
- GPIO_conf.GPIO_Pin=GPIO_Pin_15 | GPIO_Pin_13 | GPIO_Pin_14 | GPIO_Pin_12;
- GPIO_conf.GPIO_PuPd = GPIO_PuPd_NOPULL;
- GPIO_conf.GPIO_Speed=GPIO_Speed_100MHz;
- GPIO_Init(GPIOB , &GPIO_conf);
- GPIO_conf.GPIO_Mode=GPIO_Mode_OUT;
- GPIO_conf.GPIO_Pin=GPIO_Pin_3 | GPIO_Pin_2;
- GPIO_Init(GPIOA , &GPIO_conf);
- GPIO_conf.GPIO_Pin=GPIO_Pin_4;
- GPIO_Init(GPIOC , &GPIO_conf);
- /////////////////////////////////////////////////////////////////////////SPI _init
- SPI_I2S_DeInit(SPI2); //
- //GPIO_SetBits(GPIOB,GPIO_Pin_12);
- SPI_conf.SPI_Direction = SPI_Direction_2Lines_FullDuplex;
- SPI_conf.SPI_DataSize = SPI_DataSize_8b;
- SPI_conf.SPI_Mode = SPI_Mode_Master; //主机模式
- SPI_conf.SPI_CPOL = SPI_CPOL_High;
- SPI_conf.SPI_CPHA = SPI_CPHA_2Edge;
- SPI_conf.SPI_NSS = SPI_NSS_Soft;
- SPI_conf.SPI_BaudRatePrescaler = SPI_BaudRatePrescaler_2;
- SPI_conf.SPI_FirstBit = SPI_FirstBit_MSB;
- SPI_conf.SPI_CRCPolynomial = 7;
- //SPI_SSOutputCmd(SPI2,ENABLE);
- SPI_Init(SPI2, &SPI_conf);
- //SPI_NSSInternalSoftwareConfig(SPI2,SPI_NSSInternalSoft_Set);
- SPI_Cmd(SPI2, ENABLE);
- u8 spi2_datasend(u8 data)
- SPI2->DR = data; // write data to be transmitted to the SPI data register
- while( !(SPI2->SR & SPI_I2S_FLAG_TXE) ); // wait until transmit complete
- while( !(SPI2->SR & SPI_I2S_FLAG_RXNE) ); // wait until receive complete
- while( SPI2->SR & SPI_I2S_FLAG_BSY ); // wait until SPI is not busy anymore
- return SPI2->DR; // return received data from SPI data register
主要问题有两个:
1:片内NSS管脚的问题,之前没有仔细研究过后来到网上查了下资料,发现还真是门大学问啊,stm32的NSS有输入,输出两种模式,还可以分别选择软件,硬件控制,具体的使用方法可以参考下面这篇博文:(不知道怎么回事,没有权限发url……自己在前边加http吧……)
hi.baidu.com/kangxuebin/item/9a21b1f96ccaef1ba6298830
2:外部器件的NSS引脚(也就是CS引脚):当只有一个SPI设备时使用的时候可以直接接地,当有多个SPI设备,且公用一个SPI接口时,要控制CS引脚,使用该器件时拉低,不使用时拉高,达到片选的作用。
还有就是发现stm32的NSS引脚确实是有bug的,虽然st官方并不承认……那就是NSS引脚不管在什么情况下,都不能自动拉高,因此建议在使用时,把NSS引脚当做GPIO来使用。
