想在一个程序里用多个串口的printf,为什么不可以
1713|3
 楼主| lqab1983 发表于 2013-11-18 17:12 | 显示全部楼层 |阅读模式
1.STM32F103库函数里面,想用printf 而不是USARTSendData,这样好吗?
2.我在网上搜了这么一段程序,确实可以,但是不知道为什么,USART2的printf打印了12次后就再也不出数字了,串口1可以?为什么啊??
#ifdef __GNUC__
  /* With GCC/RAISONANCE, small printf (option LD Linker->Libraries->Small printf
     set to 'Yes') calls __io_putchar() */
#define PUTCHAR_PROTOTYPE int __io_putchar(int ch)
#else
  #define PUTCHAR_PROTOTYPE int fputc(int ch, FILE *f)
#endif /* __GNUC__ */
#define CMD_BUFFER_LEN 511
//u8  rev_stop = 0;     //接收停止标志
//u8  gps_flag = 0; //GPS处理标志
u8 gpgga_flag = 0;
u8 gprmc_flag = 0;
u8 gpgsv_flag = 0;
GPS_INFO GPS;
void USART2_printf (char *fmt, ...)
        char buffer[CMD_BUFFER_LEN+1];  // CMD_BUFFER_LEN长度自己定义吧
        u8 i = 0;
        va_list arg_ptr;
        va_start(arg_ptr, fmt);
        vsnprintf(buffer, CMD_BUFFER_LEN+1, fmt, arg_ptr);
        while ((i < CMD_BUFFER_LEN) && buffer)
        USART_ClearFlag(USART2,USART_FLAG_TC);
                USART_SendData(USART2, (u8) buffer[i++]);
                while (USART_GetFlagStatus(USART2, USART_FLAG_TC) == RESET);
        va_end(arg_ptr);
int main()
        char a ='c';int b = 0;
        NVIC_Configuration();
    USART1_Configuration();
    USART2_Configuration();
        USART3_Configuration();
        UART4_Configuration();
        printf("configure finshed\r\n");
        USART2_printf("%c,%d\r\n",a,b );  //12次后不出现了 为什么?
        while(1)
                if((gpgga_flag == 1) || (gprmc_flag == 1) || (gpgsv_flag == 1))
                        printf("latitude:%d.%d.%d_%c\r\n",GPS.latitude_Degree,GPS.latitude_Cent,GPS.latitude_Second,GPS.NS);
                     printf("longitude:%d.%d.%d_%c\r\n",GPS.longitude_Degree,GPS.longitude_Cent,GPS.longitude_Second,GPS.EW);
                      printf("speed:%f\r\n",GPS.speed);
                      printf("direction:%f\r\n",GPS.direction);
                        printf("satellite_num:%d\r\n",GPS.satellite);
                      printf("height_ground:%f\r\n",GPS.height_ground);
                       printf("height_sea:%f\r\n",GPS.height_sea);
                        printf("Time :%d%d%d-%d%d%d\r\n",GPS.D.year,GPS.D.month,GPS.D.day,GPS.D.hour,GPS.D.minute,GPS.D.second);
                        gpgga_flag = 0;
                        gprmc_flag = 0;
                        gpgsv_flag = 0;
                     USART_ITConfig(UART4,USART_IT_RXNE,ENABLE);  //开启USART2 接收中断
#if 1
#pragma import(__use_no_semihosting)
struct __FILE
        int handle;
FILE __stdout;
_sys_exit(int x)
        x = x;
#endif
  * @brief  Retargets the C library printf function to the USART1.
  * @param  None
  * @retval None
PUTCHAR_PROTOTYPE
  /* Place your implementation of fputc here */
  /* e.g. write a character to the USART */
  USART_ClearFlag(USART1,USART_FLAG_TC);
  USART_SendData(USART1, (uint8_t) ch);
  /* Loop until the end of transmission */
  while (USART_GetFlagStatus(USART1, USART_FLAG_TC) == RESET)
  return ch;
puchuang 发表于 2013-11-18 19:35 | 显示全部楼层
不是很了解   楼主   这一块  了解的不多   先顶一个   帮你
 楼主| lqab1983 发表于 2013-11-19 09:12 | 显示全部楼层
谁用过多个串口的同时printf帮帮啊?
airwill 发表于 2013-11-19 18:06 | 显示全部楼层
按理不应该, 是不是软件有 bug?
