[Quartus] quartus 11.0SP1报错!!!!
2527|0
 楼主| daixi520 发表于 2013-11-19 21:27 | 显示全部楼层 |阅读模式
quartus 11.0SP1报错!!!!求大神解决
xp下先安装11.0sp1_quartus_windows.exe,然后安装11.0_devices_windows.exe;最后使用sp1的crack**,但是新建quartus工程时出现以下错误:
Internal Error: Sub-system: PDB, File: /quartus/db/pdb/pdb_archive.cpp, Line: 2851
pdb_id <= object_info->m_ptr_table_size
Stack Trace:
    0x240d: err_report_internal_error + 0x1d (CCL_ERR)
    0x9424: __alldiv + 0x11d4 (DB_PDB)
    0x6712: PDB_SEGMENT_READER:fr_ptr + 0x12 (DB_PDB)
    0x1d1d0: pdb_array_xfr_<DB_DDB_SEG_BASE,DEV_ELEMENT_DESC * [1311]> + 0x40 (DDB_DEV)
    0x4da3: DEV_BASIC_INFO_BODY:perator<< + 0x173 (DDB_DEV)
    0x1ce3b: PDB_BASE_CLASS_THUNK<DEV_BASIC_INFO_BODY>::constructor + 0x3b (DDB_DEV)
    0x7429: PDB_OBJECT_INFO:inish_reading + 0x39 (DB_PDB)
    0x25ed: pdb_read_ptr + 0x7d (DB_PDB)
    0x1c6b6: pdb_read_<DB_ARCHIVE,DEV_BASIC_INFO_BODY> + 0x96 (DDB_DEV)
    0x16f66: DEV_BASIC_INFO_BODY::load_hdr_from_pdb + 0x206 (DDB_DEV)
    0x1836c: DEV_BASIC_INFO::load_data + 0x10c (DDB_DEV)
    0x3c83: MEM_SEGMENT_INTERNAL::allocate + 0x43 (ccl_mem)
    0x3d43: operator new + 0x63 (ccl_mem)
    0xe5a4: _Dinkum_std::basic_string<char,_Dinkum_std::char_traits<char>,MEM_STL_ALLOCATOR<char> >::assign + 0x84 (DDB_DEV)
    0x2953f: DEV_BASIC_INFO_BODY::set_enum_data + 0x2f (DDB_DEV)
    0x665d: DMGR_UTILITY_BODY::create_basic_info + 0x23d (DDB_DMGR)
    0x108b8: DMGR_UTILITY_BODY::create_typical_device + 0x2f8 (DDB_DMGR)
    0x488b9: DSET_DEVICE::init_device_list_headers + 0xe9 (saui_dset)
    0x63db7: malloc + 0x78 (MSVCR90)
    0x6fbab: _dset_device + 0x5b (saui_dset)
    0x2a3f: BMWQ_NPW_DEVICE::BMWQ_NPW_DEVICE + 0xcf (sys_bmwq)
    0x1115a: _bmwq_dyn_new_project_wizard + 0x47a (sys_bmwq)
    0x515fa: QUI_PRJ_UI_MGR::new_prj_wiz_action + 0x26a (SYS_QUI)
    0xe16a: QUI_FRAME_WND::qt_metacall + 0x8fa (SYS_QUI)
    0x88ba: QGQ_MAIN_WINDOW::qt_metacall + 0x1a (SYS_QGQ)
    0xe0eae: QMetaObject::metacall + 0x3e (QtCore4)
    0xc57d: QAction::activate + 0xcd (QtGui4)
  0x348a28: QMenu:indIdForAction + 0x288 (QtGui4)
  0x34e500: QMenu::internalDelayedPopup + 0x680 (QtGui4)
End-trace
