[DSP编程] error-warning-remarks解释
1630|0
 楼主| zhangmangui 发表于 2013-11-24 22:13 | 显示全部楼层 |阅读模式
  • 可以看一下下面对error, warning, remarks的解释.
    ?An error indicates a violation of the syntax or semantic rules of the C/C++ language. Compilation continues, but object code is not generated.
    ?A warning indicates something that is valid but questionable. Compilation continues and object code is generated (if no errors are detected).
    ?A remark is less serious than a warning. It indicates something that is valid and probably intended, but may need to be checked. Compilation continues and object code is generated (if no errors are detected). By default, remarks are not issued. Use the -pdr compiler option to enable remarks.
    英文的   兄弟们要习惯啦
个人签名:欢迎进入【TI DSP 论坛】 & 【DSP 技术】           TI忠诚粉丝!
935
