[STM8] STM8L152C8 48pin DAC无输出
1843|3
 楼主| mov_zh 发表于 2013-11-25 09:02 | 显示全部楼层 |阅读模式
原程序:
void main(void)
  DAC_DeInit();
  /* Enable the Clock of DAC */
  CLK_PeripheralClockConfig(CLK_Peripheral_DAC, ENABLE);
  CLK_PeripheralClockConfig(CLK_Peripheral_COMP, ENABLE);
  COMP_TriggerConfig(COMP_TriggerGroup_DACOutput,COMP_TriggerPin_1,ENABLE);
  /* Init DAC channel 1 and DAC channel 2 outputs */
  DAC_Init(DAC_Channel_1, DAC_Trigger_Software, DAC_OutputBuffer_Enable);
  DAC_Init(DAC_Channel_2, DAC_Trigger_Software, DAC_OutputBuffer_Enable);
  /* Enable DAC channel 1 and 2 outputs  */
  DAC_Cmd(DAC_Channel_1, ENABLE);
  DAC_Cmd(DAC_Channel_2, ENABLE);
  DAC_SetChannel1Data(DAC_Align_12b_R,2030);
  DAC_SetChannel2Data(DAC_Align_12b_R,2030);
  /* Infinite loop */
  while (1)
    DAC_DualSoftwareTriggerCmd(ENABLE);
DAC1有输出
DAC2没有输出 请ST 技术支持和那位高手指点下!谢谢!
自己先顶一下!!!
 楼主| mov_zh 发表于 2013-11-25 18:27 | 显示全部楼层
没人气啊!
marshallemon 发表于 2015-11-6 14:53 | 显示全部楼层
貌似152只有一个DAC通道吧?
