C2000无法仿真问题
1086|2
 楼主| xichengmadia 发表于 2013-11-28 22:59 | 显示全部楼层 |阅读模式
Error connecting to the target:
(Error -151 @ 0x0)
One of the FTDI driver functions used during
the connect returned bad status or an error.
The cause may one or more of: invalid emulator serial number,
blank emulator EEPROM, missing FTDI drivers, faulty USB cable.
Use the xds100serial command-line utility in the 'common/uscif'
folder to verify the emulator can be located.
(Emulation package 5.1.73.0)
这个错误怎么解决呢?
 楼主| xichengmadia 发表于 2013-11-28 23:00 | 显示全部楼层
不知道CCS里测试目标连接是否可以
tianli1980 发表于 2013-11-29 19:23 | 显示全部楼层
楼主卸载驱动,重新安装一下试试看。
