[嵌入式linux]
QT embedded
1648|2
swimchang|  楼主 | 2013-12-4 11:51 | 只看该作者 回帖奖励 |倒序浏览 |阅读模式
QT軟件: qt-everywhere-opensource-src-4.6.0
gcc compile : gcc-4.4.4-glibc-2.11.1-multilib-1.0
./configure -opensource -confirm-license -embedded arm -glib -phonon -phonon-backend -v -qt-zlib -qt-libpng -qt-gif -qt-libtiff -qt-libmng -qt-libjpeg -qt-freetype -no-openssl -force-pkg-config -nomake tools -nomake examples -nomake demos -nomake docs -qt-gfx-transformed -qt-gfx-linuxfb -little-endian -qt-mouse-tslib -I/opt/tslib/include -L/opt/tslib/lib -I/usr/include/glib-2.0 -I/usr/lib/glib-2.0/include -L/usr/lib
所產生錯誤訊息:
Glib disabled.
Glib support cannot be enabled due to functionality tests!
Turn on verbose messaging (-v) to ./configure to see the final report.
If you believe this message is in error you may use the continue
switch (-continue) to ./configure to continue.
請問有解嗎?
黄小俊| | 2013-12-4 12:51 | 只看该作者
,帮顶
287651380| | 2014-1-23 15:26 | 只看该作者
