[8/16-bit MCU] 关于XEP100.h中宏定义的问题
2432|1
 楼主| xinxinyuan 发表于 2013-12-13 21:47 | 显示全部楼层 |阅读模式
定义如下:
volatile DDRABSTR _DDRAB;                /* Port AB Data Direction Register; 0x00000002 */
typedef union {
  word Word;
   /* Overlapped registers: */
  struct {
    /*** DDRA - Port A Data Direction Register; 0x00000002 ***/
    union {
      byte Byte;
      struct {
        byte DDRA0       :1;                                       /* Data Direction Port A Bit 0 */
        byte DDRA1       :1;                                       /* Data Direction Port A Bit 1 */
        byte DDRA2       :1;                                       /* Data Direction Port A Bit 2 */
        byte DDRA3       :1;                                       /* Data Direction Port A Bit 3 */
        byte DDRA4       :1;                                       /* Data Direction Port A Bit 4 */
        byte DDRA5       :1;                                       /* Data Direction Port A Bit 5 */
        byte DDRA6       :1;                                       /* Data Direction Port A Bit 6 */
        byte DDRA7       :1;                                       /* Data Direction Port A Bit 7 */
      } Bits;
    } DDRASTR;
    #define DDRA                        _DDRAB.Overlap_STR.DDRASTR.Byte
    #define DDRA_DDRA0                  _DDRAB.Overlap_STR.DDRASTR.Bits.DDRA0
    #define DDRA_DDRA1                  _DDRAB.Overlap_STR.DDRASTR.Bits.DDRA1
    #define DDRA_DDRA2                  _DDRAB.Overlap_STR.DDRASTR.Bits.DDRA2
    #define DDRA_DDRA3                  _DDRAB.Overlap_STR.DDRASTR.Bits.DDRA3
    #define DDRA_DDRA4                  _DDRAB.Overlap_STR.DDRASTR.Bits.DDRA4
    #define DDRA_DDRA5                  _DDRAB.Overlap_STR.DDRASTR.Bits.DDRA5
    #define DDRA_DDRA6                  _DDRAB.Overlap_STR.DDRASTR.Bits.DDRA6
    #define DDRA_DDRA7                  _DDRAB.Overlap_STR.DDRASTR.Bits.DDRA7
    #define DDRA_DDRA0_MASK             1
    #define DDRA_DDRA1_MASK             2
    #define DDRA_DDRA2_MASK             4
    #define DDRA_DDRA3_MASK             8
    #define DDRA_DDRA4_MASK             16
    #define DDRA_DDRA5_MASK             32
    #define DDRA_DDRA6_MASK             64
    #define DDRA_DDRA7_MASK             128
    /*** DDRB - Port B Data Direction Register; 0x00000003 ***/
    union {
      byte Byte;
      struct {
        byte DDRB0       :1;                                       /* Data Direction Port B Bit 0 */
        byte DDRB1       :1;                                       /* Data Direction Port B Bit 1 */
        byte DDRB2       :1;                                       /* Data Direction Port B Bit 2 */
        byte DDRB3       :1;                                       /* Data Direction Port B Bit 3 */
        byte DDRB4       :1;                                       /* Data Direction Port B Bit 4 */
        byte DDRB5       :1;                                       /* Data Direction Port B Bit 5 */
        byte DDRB6       :1;                                       /* Data Direction Port B Bit 6 */
        byte DDRB7       :1;                                       /* Data Direction Port B Bit 7 */
      } Bits;
    } DDRBSTR;
    #define DDRB                        _DDRAB.Overlap_STR.DDRBSTR.Byte
    #define DDRB_DDRB0                  _DDRAB.Overlap_STR.DDRBSTR.Bits.DDRB0
    #define DDRB_DDRB1                  _DDRAB.Overlap_STR.DDRBSTR.Bits.DDRB1
    #define DDRB_DDRB2                  _DDRAB.Overlap_STR.DDRBSTR.Bits.DDRB2
    #define DDRB_DDRB3                  _DDRAB.Overlap_STR.DDRBSTR.Bits.DDRB3
    #define DDRB_DDRB4                  _DDRAB.Overlap_STR.DDRBSTR.Bits.DDRB4
    #define DDRB_DDRB5                  _DDRAB.Overlap_STR.DDRBSTR.Bits.DDRB5
    #define DDRB_DDRB6                  _DDRAB.Overlap_STR.DDRBSTR.Bits.DDRB6
    #define DDRB_DDRB7                  _DDRAB.Overlap_STR.DDRBSTR.Bits.DDRB7
    #define DDRB_DDRB0_MASK             1
    #define DDRB_DDRB1_MASK             2
    #define DDRB_DDRB2_MASK             4
    #define DDRB_DDRB3_MASK             8
    #define DDRB_DDRB4_MASK             16
    #define DDRB_DDRB5_MASK             32
    #define DDRB_DDRB6_MASK             64
    #define DDRB_DDRB7_MASK             128
  } Overlap_STR;
  struct {
    word DDRB0       :1;                                       /* Data Direction Port B Bit 0 */
    word DDRB1       :1;                                       /* Data Direction Port B Bit 1 */
    word DDRB2       :1;                                       /* Data Direction Port B Bit 2 */
    word DDRB3       :1;                                       /* Data Direction Port B Bit 3 */
    word DDRB4       :1;                                       /* Data Direction Port B Bit 4 */
    word DDRB5       :1;                                       /* Data Direction Port B Bit 5 */
    word DDRB6       :1;                                       /* Data Direction Port B Bit 6 */
    word DDRB7       :1;                                       /* Data Direction Port B Bit 7 */
    word DDRA0       :1;                                       /* Data Direction Port A Bit 0 */
    word DDRA1       :1;                                       /* Data Direction Port A Bit 1 */
    word DDRA2       :1;                                       /* Data Direction Port A Bit 2 */
    word DDRA3       :1;                                       /* Data Direction Port A Bit 3 */
    word DDRA4       :1;                                       /* Data Direction Port A Bit 4 */
    word DDRA5       :1;                                       /* Data Direction Port A Bit 5 */
    word DDRA6       :1;                                       /* Data Direction Port A Bit 6 */
    word DDRA7       :1;                                       /* Data Direction Port A Bit 7 */
  } Bits;
  struct {
    word grpDDRB :8;
    word grpDDRA :8;
  } MergedBits;
} DDRABSTR
请问如上代码中的_DDRAB到底是什么?
 楼主| xinxinyuan 发表于 2013-12-14 10:13 | 显示全部楼层
错了,应该是联合体的定义
个人签名:<img src="static/image/smiley/comcom/3.gif" class="vm"> ...
19
