| file:///C:/Users/0/AppData/Local/Temp/msohtmlclip1/01/clip_image002.gif天微电子 LED显示驱动 | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | 11段/7位 12段/6位 13段/5位 14段/4位 | | | | | | | | | | 11段/7位 12段/6位 13段/5位 14段/4位 | | | | | | | | | | 10段/7位 11段/6位 12段/5位 13段/4位 | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | file:///C:/Users/0/AppData/Local/Temp/msohtmlclip1/01/clip_image002.gif天微电子 LCD显示驱动 | | | | | | | | 32seg*4com,128点阵,4*6按键,4路PWM背光数出 | | | | | | 20seg*4com 80点阵 4*3按键,4路PWM背光输出 | | | | | | | | | | |
file:///C:/Users/0/AppData/Local/Temp/msohtmlclip1/01/clip_image004.jpg | file:///C:/Users/0/AppData/Local/Temp/msohtmlclip1/01/clip_image002.gif天微电子 LCD显示驱动 | | | | | 2个全差分输入通道,16位无丢失代码,0.003%非线性 兼容AD7705 | | | 3个伪差分输入通道,16位无丢失代码,0.003%非线性 | | | 1个全差分输入通道,16位无丢失代码,0.003%非线性 | | | 2个全差分输入通道,24位无丢失代码,0.003%非线性 | | | 3个伪差分输入通道,24位无丢失代码,0.003%非线性 | | | 1个全差分输入通道,24位无丢失代码,0.003%非线性 | | | 2个全差分输入通道,24位无丢失代码,0.003%非线性,内置振荡 | |
