大家好,我使用 stm32f103 的 USB 做了个鼠标程序,然后想通过 串口发送数据,然后将数据通过USB口返还给主机,从而测试 USB 功能,结果发现程序不能进入串口中断,我在终端里面接收数据的。请大家帮忙分析下原因。
- GPIO_InitTypeDef GPIO_InitStructure;
- USART_InitTypeDef USART_InitStructure;
- /* config USART1 clock */
- RCC_APB2PeriphClockCmd(RCC_APB2Periph_USART1 | RCC_APB2Periph_GPIOA, ENABLE);
- /* USART1 GPIO config */
- /* Configure USART1 Tx (PA.09) as alternate function push-pull */
- GPIO_InitStructure.GPIO_Pin = GPIO_Pin_9;
- GPIO_InitStructure.GPIO_Mode = GPIO_Mode_AF_PP;
- GPIO_InitStructure.GPIO_Speed = GPIO_Speed_50MHz;
- GPIO_Init(GPIOA, &GPIO_InitStructure);
- /* Configure USART1 Rx (PA.10) as input floating */
- GPIO_InitStructure.GPIO_Pin = GPIO_Pin_10;
- GPIO_InitStructure.GPIO_Mode = GPIO_Mode_IN_FLOATING;
- /* USART1 mode config */
- USART_InitStructure.USART_BaudRate = 115200;
- USART_InitStructure.USART_WordLength = USART_WordLength_8b;
- USART_InitStructure.USART_StopBits = USART_StopBits_1;
- USART_InitStructure.USART_Parity = USART_Parity_No ;
- USART_InitStructure.USART_HardwareFlowControl = USART_HardwareFlowControl_None;
- USART_InitStructure.USART_Mode = USART_Mode_Rx | USART_Mode_Tx;
- USART_Init(USART1, &USART_InitStructure);
- USART_ITConfig(USART1, USART_IT_RXNE, ENABLE);
- USART_Cmd(USART1, ENABLE);
以上是串口的初始化代码。
- void INTERRUPT_Config(void)
- NVIC_InitTypeDef NVIC_InitStructure;
- NVIC_PriorityGroupConfig(NVIC_PriorityGroup_2);
- NVIC_InitStructure.NVIC_IRQChannel = USB_LP_CAN1_RX0_IRQn;
- NVIC_InitStructure.NVIC_IRQChannelPreemptionPriority = 2;
- NVIC_InitStructure.NVIC_IRQChannelSubPriority = 0;
- NVIC_InitStructure.NVIC_IRQChannelCmd = ENABLE;
- NVIC_Init(&NVIC_InitStructure);
- /* Enable the USB Wake-up interrupt */
- NVIC_InitStructure.NVIC_IRQChannel = USBWakeUp_IRQn;
- NVIC_InitStructure.NVIC_IRQChannelPreemptionPriority = 1;
- NVIC_InitStructure.NVIC_IRQChannel = USART1_IRQn;
- NVIC_InitStructure.NVIC_IRQChannelPreemptionPriority = 3;
- NVIC_InitStructure.NVIC_IRQChannelSubPriority = 1;
这个是中断初始化代码。
- * Function Name : USB_LP_CAN_RX0_IRQHandler
- * Description : This function handles USB Low Priority or CAN RX0 interrupts
- * requests.
- * Input : None
- * Output : None
- * Return : None
- void USB_LP_CAN1_RX0_IRQHandler(void)
- USB_Istr();
- * Function Name : USBWakeUp_IRQHandler
- * Description : This function handles USB WakeUp interrupt request.
- * Input : None
- * Output : None
- * Return : None
- void USBWakeUp_IRQHandler(void)
- EXTI_ClearITPendingBit(EXTI_Line18);
- * Function Name : USART1_IRQHandler
- * Description : This function handles USART1 global interrupt request.
- * Input : None
- * Output : None
- * Return : None
- void USART1_IRQHandler(void)
- USART1_IRQHandler_Fun();
这是 USB 与串口的中断函数,该做的基本都做了,而且串口中断接收专门建立了个工程测试是能使用的,但是加入USB 模块后就不能进入中断了,大家帮帮忙!谢谢了!
