C2000无法仿真了
1405|5
 楼主| justbybing 发表于 2013-12-30 23:01 | 显示全部楼层 |阅读模式
Error connecting to the target:
(Error -151 @ 0x0)
One of the FTDI driver functions used during
the connect returned bad status or an error.
The cause may one or more of: invalid emulator serial number,
blank emulator EEPROM, missing FTDI drivers, faulty USB cable.
Use the xds100serial command-line utility in the 'common/uscif'
folder to verify the emulator can be located.
(Emulation package 5.1.73.0)
我卸载驱动,重新安装,提示需重启电脑,然后我就重启,还是不行啊
huangfeng33 发表于 2014-1-11 19:24 | 显示全部楼层
这个应该是驱动没有安装对的原因,楼主再重新检查下。
chaxiangpaigu 发表于 2014-10-15 15:37 | 显示全部楼层
can't initialize target cpu:
error 0x80002240/-151
fatal error during:initialization,ocs,control,
this error was generated by IT's USCIF driver.
SC_ERR_POD_OPEN <-151>
This utility failed to open the adapter for a custom emulator.
The adapter returned an error.
请问这是个什么问题呀 怎么解决不了啊  谢谢啦
wangch_sh 发表于 2014-10-15 17:44 | 显示全部楼层
是一直不能仿真,还是原来可以,现在不行了?
拿起书本 发表于 2014-10-29 14:43 | 显示全部楼层
软件的安装顺序。CCS-----CCS补丁----USB驱动---CCS驱动。建议严格按照上面的顺序来。
