4*8段式LCD,用stc12c5a60s2驱动,显示很暗,求解答谢谢。
1079|0
 楼主| 孟令民 发表于 2014-1-13 16:41 | 显示全部楼层 |阅读模式
#include<c:\Keil\C51\INC\STC\STC12c5a60S2.H>
#define uchar unsigned char
#define uint unsigned int
sbit COM3=P2^3;
sbit COM2=P2^2;
sbit COM1=P2^1;
sbit COM0=P2^0;
sbit key1=P2^7;
uchar i;
unsigned char ScanCoun=0;
unsigned char C0[10]={0x01,0x00,0x01,0x01,0x00,0x01,0x01,0x01,0x01,0x01};
unsigned char C1[10]={0x03,0x02,0x02,0x02,0x03,0x01,0x01,0x02,0x03,0x03};
unsigned char C2[10]={0x01,0x00,0x03,0x02,0x02,0x02,0x03,0x00,0x03,0x02};
unsigned char C3[10]={0x03,0x02,0x01,0x03,0x02,0x03,0x03,0x02,0x03,0x03};
void delay(uint z)
uint x,y;
for(x=z;x>0;x--)
  for(y=110;y>0;y--);
key()                   // °´¼üº¯Êý
if(key1==0)
delay(10);
if(key1==0)
i++;
if(i>9)
i=0;
while(key1==0);
void  main(void)
   TMOD = 0x01;
   ET0 = 1;
   EA = 1;
   TR0 = 1;
   EA=1; //¿ªÈ«¾Ö×ÜÖжÏ
   while(1)
void Timer0() interrupt 1     //¶¨Ê±Æ÷ÖжÏ
     TL0=0x78; //¶¨Ê±5ms
    TH0=0xec;
   P2M1 =0x0f;
    P2M0 =0x00;
    key();
     switch(ScanCoun)   //¶¯Ì¬É¨ÃèÏÔʾ
    case 0:                //COM3正向驱动
   COM0=1;
  COM1=1;
  COM2=1;
  COM3=0;
   P0=C0;
  P2M1 =0x07;
  P2M0 =0x00;
   break;
  case 1 :               //COM3反向驱动
  COM0=0;
  COM1=0;
   COM2=0;
   COM3=1;
  P0=~C0;
  P2M1 =0x07;
  P2M0 =0x00;
  break;
   case 2:              //COM2正向驱动
   COM0=1;
   COM1=1;
   COM2=0;
   COM3=1;
  P0=C1;
  P2M1 =0x0b;
  P2M0 =0x00;
  break;
   case 3:                //COM2反向驱动
  COM0=0;
  COM1=0;
  COM2=1;
  COM3=0;
   P0=~C1;
  P2M1 =0x0b;
   P2M0 =0x00;
   break;
    case 4:               //COM1正向驱动
  COM0=1;
  COM1=0;
  COM2=1;
  COM3=1;
   P0=C2;
  P2M1 =0x0d;
   P2M0 =0x00;
   break;
   case 5:               //COM1反向驱动
  COM0=0;
  COM1=1;
  COM2=0;
  COM3=0;
   P0=~C2;
  P2M1 =0x0d;
   P2M0 =0x00;
   break;
   case 6 :             //COM0正向驱动
  COM0=0;
  COM1=1;
  COM2=1;
  COM3=1;
   P0=C3;
  P2M1 =0x0e;
   P2M0 =0x00;
   break;
    case 7:              //COM0反向驱动
  COM0=1;
  COM1=0;
  COM2=0;
  COM3=0;
   P0=~C3;
  P2M1 =0x0e;
   P2M0 =0x00;
   break;
      ScanCoun++;       //加一
     if (ScanCoun>7) ScanCoun=0;
个人签名:天宏科技 专业 专注温控工控自动化 QQ 496542965
54
