44b0声音的播放
3046|2
syzhou1314|  楼主 | 2007-1-8 17:27 | 只看该作者 回帖奖励 |倒序浏览 |阅读模式
各位dx好:
    我正在用三星44b0实验箱做一个语音电子时钟,现需连续播放两段wave声音,一段是欢迎使用(huanying.wav总共404858字节,除去44字节的头文件信息是404814字节),另一段是播报日期的声音(nian.wav总共是156698字节,除去44字节的头文件信息是156654字节),两者总共播放时间不过5秒,在程序中定义的播放buffer缓冲区”int buffer[AUDIO_IN_BUFFERSIZE*20];“大小是1764000字节(>(404814+156654))我的做法是先把huanying.wav读到缓冲区buffer的0~404813中,然后把nian.wav读到404814~561467中,然后在把buffer作为dma的源地址进行播放!单结果只是播放了huanying.wav,后面的没出来,请问是什么原因?错在哪里》》÷??
一下是程序:
void Main_Task(void *Id)             //Main_Test_Task
{   u32 toubyte;
 U32 nbyte;
 FILE *pfile;
 FILE *pfile1;
 char filename[]="huanying.wav";//erlingling
 char filename1[]="nian.wav";
    int aa=1;
 rIISCON=0; //disable;
 rIISMOD=IISMOD_TX|IISMOD_16BIT|IISMOD_32FS|IISMOD_MCLK_384FS;
 rIISFCON=IISFCON_TXDMA|IISFCON_TXFIFO;
 rIISPSR=0x11;
 rIISCON=IISCON_PRESCALE|IISCON_ENABLE;
 Init_UDA1341();
 pfile=OpenOSFile(filename, FILEMODE_READ);
 if(!pfile)
  return ;
 pfile1=OpenOSFile(filename1, FILEMODE_READ);
 if(!pfile1)
  return ;
 toubyte=ReadOSFile(pfile, (U8*) buffer, 0x16*2);//读取头文件信息
 nbyte=ReadOSFile(pfile, (U8*) buffer, 404814);//读取波形数据
 Uart_Printf(" huanying file tounbyte=%d  nbyte=%d sizeofbuff=%d ",toubyte,nbyte,sizeof(buffer));
 toubyte=ReadOSFile(pfile1, (U8*) (buffer+404814), 0x16*2);//读取头文件信息
 Uart_Printf(" nian tounbyte=%d ",toubyte);
 nbyte=ReadOSFile(pfile1, (U8*) (buffer+404814),156654);//读取波形数据
 Uart_Printf(" nian file tounbyte=%d  nbyte=%d sizeofbuff=%d ",toubyte,nbyte,sizeof(buffer));
 for(;;)
 {//死循环
  /****** BDMA0 Initialize ******/
  //for Source
  rBDISRC0=(1<<30)+(1<<28)+(int)buffer; //Half word,inc,Buf
  //for des
  rBDIDES0=(1<<30)+(3<<28)+((int)0x1d18010); //M2IO,fix,IISFIF
  //Size
  //iis,reserve,done_int,not auto-reload/start,DMA enable,COUNT
  rBDICNT0=(1<<30)+(1<<26)+(3<<22)+(0<<21)+(0<<20)+(sizeof(buffer)&(~0x3));
  rBDICNT0 |= (1<<20);//enable
  //Enable DMA
  rBDCON0 = 0x0<<2;
  //Tx DMA
  rIISCON|=IISCON_TXDMA;
这是超级终端的结果:
File huanyingwav have been read!
File nian    wav have been read!
huanying file tounbyte=44        nbyte=404814 sizeofbuff=1764000
nian tounbyte=44
nian file tounbyte=44    nbyte=156654 sizeofbuff=1764000
恳请指教!
pigjiang| | 2007-1-8 18:15 | 只看该作者
用的UC/OS II ?
syzhou1314|  楼主 | 2007-1-8 19:59 | 只看该作者
对,是用的uc/os!
对,是用的uc/os!
哥哥说说
