[AVR单片机] 关于GYTF018M1BOM显示屏跟ATMEGA16程序问题
1793|1
 楼主| aa561950690 发表于 2014-2-12 21:21 | 显示全部楼层 |阅读模式
有大神帮下忙吗,下面这些程序是根据51自己改成meg16的程序,弄了2天多了,一点头绪都没有
lcd.c文件
*                                   彩屏驱动程序                                                          *
#include <iom16v.h>
#include "lcd.h"
uint colors[]=
  0xf800,0x07e0,0x001f,0xffe0,0x0000,0x07ff,0xf81f,0xffff
延时子函数
void delay_ms(uint ms)
  unsigned char k;
  while (ms--)
    for (k = 0; k < 228; k++)
写8位数据子函数
void WriteDAT(uchar value)    // color data
        LCD_CS_L;
        LCD_RS_H;
//        LCD_WR  = 0;
        PORTB=value;
    LCD_WR_L;
        LCD_WR_H;
           LCD_CS_H;
写8位命令子函数
void WriteCOM(uchar value)    // color data
        LCD_CS_L;
        LCD_RS_L;
//        LCD_WR  =  0;
        PORTB=value;
        LCD_WR_L;
        LCD_WR_H;
           LCD_CS_H;
设置显示窗口子函数
void LCD_SetRamAddr(uint xStart, uint xEnd, uint yStart, uint yEnd)
        WriteCOM(0x2a);                   //行
        WriteDAT(xStart>>8);   //XS15-XS8
        WriteDAT(xStart);           //XS7-XS0    (X start address)
        WriteDAT(xEnd>>8);           //XE15-XE8
        WriteDAT(xEnd);                   //XE7-XE0    (X end address)
        WriteCOM(0x2b);                   //列        row address set (RASET)
        WriteDAT(yStart>>8);   //YS15-YS8
        WriteDAT(yStart);           //YS7-YS0    (Y start address)
        WriteDAT(yEnd>>8);           //YE15-YE8
        WriteDAT(yEnd);                   //YE7-YE0    (Y end address)
    WriteCOM(0x2c);                   //display on        显示打开命令
void LCD_init(void)
{         //请看数据手册的命令部分 了解其个命令的功能
        LCD_RST_H;
        delay_ms(100);
        LCD_RST_L;
        delay_ms(100);
        LCD_RST_H;
        delay_ms(100);
        WriteCOM(0x01);            //software reset软件复位
        delay_ms(100);
        WriteCOM(0x11);            //sleep out/power on(SLPOUT) 退出睡眠
        delay_ms(50);
        WriteCOM(0x20);                //display inversion off 关闭取反
        delay_ms(50);
        WriteCOM(0x38);            //ID mode off (IDMOFF)
        delay_ms(50);
        WriteCOM(0x13);            //Normal display mode on (Partial mode off)
        WriteCOM(0x3a);            //color mode Interface pixel format  (COLMOD)
        WriteDAT(0x05);                //16-bit/pixel , 1-times data transfer
        WriteCOM(0xc0);                //power control 1      (PWCTR1)
        WriteDAT(0x03);                //default value  LCM=0 set the GVDD voltage=4.65
        WriteCOM(0xc5);
        WriteDAT(0xc8);           //VCOMH voltage set 4.300V
        WriteCOM(0xc6);
        WriteDAT(0x1f);           //VCOMAC voltage set 5.550V ;
        delay_ms(10);
        WriteCOM(0xfe);
        WriteDAT(0x00);
        WriteDAT(0x04);
        WriteCOM(0x26);           //gamma sel
        WriteDAT(0x04);
        WriteCOM(0x2a);           //column address set (CASET)
        WriteDAT(0x00);           //XS15-XS8
        WriteDAT(0x00);           //XS7-XS0    (X start address)
        WriteDAT(0x00);           //XE15-XE8
        WriteDAT(0x7f);           //XE7-XE0    (X end address)
        WriteCOM(0x2b);           //row address set (RASET)
        WriteDAT(0x00);           //YS15-YS8
        WriteDAT(0x00);           //YS7-YS0    (Y start address)
        WriteDAT(0x00);           //YE15-YE8
        WriteDAT(0x9f);           //YE7-YE0    (Y end address)
        WriteCOM(0x36);           //memory data access control  (MADCTR)
        WriteDAT(0xc0);
        WriteCOM(0x29);          // display on
清屏子函数
void  LCD_clear(uchar n)
   uint num;
   LCD_SetRamAddr(0,127, 0,159);  //设置显示的坐标
   for(num=20480;num>0;num--)          //160*128=20480
           WriteDAT(colors[n]>>8);   //高8位
         WriteDAT(colors[n]);           //低8位
lcd.h文件
file:  Lcd.h
file:  Lcd.h
#define uchar unsigned char
#define uint unsigned int
#define  TYPE_LCD_DATA                1
#define  TYPE_LCD_COMMAND        0
#define  LCD_SIZE_X                128
#define  LCD_SIZE_Y                160
#define  DATA   PORTB
#define LCD_RST_H    PORTD|=(1 << PD6)
#define LCD_RST_L    PORTD&=~(1 << PD6)
//RST 引脚定义
//#define LCD_RD_H            PORTD|=(1 << PD7)
//#define LCD_RD_L     PORTD&=~(1 << PD7)
//RD  引脚定义
#define LCD_WR_H     PORTC|=(1 << PC3)
#define LCD_WR_L     PORTC&=~(1 << PC3)
//WR  引脚定义
#define LCD_RS_H     PORTD|=(1 << PD5)
#define LCD_RS_L     PORTD&=~(1 << PD5)
//RS  引脚定义
#define LCD_CS_H     PORTD|=(1 << PD4)
#define LCD_CS_L     PORTD&=~(1 << PD4)
//CS  引脚定义
extern  uint colors[];
extern  void  delay_ms(uint ms);
extern  void  LCD_SetRamAddr(uint xStart, uint xEnd, uint yStart, uint yEnd);
extern  void  LCD_init(void);
extern  void  LCD_clear(uchar n);
extern  void  LCD_ShowChar(uchar x,uchar y,uint For_color,uint Bk_color,char ch);
extern  void  LCD_ShowString(uchar x,uchar y,uint For_color,uint Bk_color,char *p);
extern  void ChineseChar(uint x,uint y,int size,uint For_color, uint Bk_color , char c);
void WriteDAT(uchar value) ;
main函数
#include <iom16v.h>
#include "lcd.h"
  主函数
void main(void)
   DDRB = 0xff;
   DDRC = 0xff;
   DDRD = 0xff;
   LCD_init();
   LCD_clear(6);
   while(1)        ;
qin552011373 发表于 2014-2-14 15:34 | 显示全部楼层
才两天多,自己再仔细看看,结合你用的外围器件的手册,提示一点:avr的速度比51快很多,移植的过程中注意你的延时函数是否还正确
